Hi Folks,
You may or may not have heard of Ultraseal. It is a pre-flat preventative injected into the tires, usually when new. The tires must be balanced prior to the addition of Ultraseal. This product not only prevents flat tires from punctures up to 1/4", but also eliminate slow leaks and adds life to the tires. I discovered this product from favorable comments on the Evilution web site in England (
www.evilution.co.uk). The key to this product is to use the exact amount required for the size of the tire. For the 145 & 175 size tires, 8 oz and 10 oz of Ultraseal is required in each tire. That's only 36 oz total of the 128, so there is plenty for another car you may have. Total cost of the gallon is $49 plus freight. This product is used by the Federal government for all Postal Service vehicles in the US. A higher strength version is used for the army in Humvees. That product prevents flats even if a bullet pierces both sides of the tire. It's just another option if anyone is interested. We did this research about 6 months ago when we thought there should be an alternative to the "no spare" problem.
Ron Gaus, aSmartCar.com
