late edit:
whoops, i just noticed, this thread is for the 450. in the below, im thinking ahead, for use on the 451.
to save space, the 12v a/c sounds good. i picked up one for about $7 or so a while ago. amazing, i used it tonight to top off the tire pressure, on a buick lesabre, to 34, from 25 or so, and worked fine.
just plug into the cigarette plug, turn on the engine to keep the battery charged, and attach it to value stem, & watch the built in gauge to the right pressure.
guess i could put that in the smart. and a tire plugger repair little kit.
what about a small spare, they put in cars, to save space, rather than the full size spare? is one available, that would fit on either the front or rear tire spot?
small enough, to store in the trunk, and still leave a little trunk room?
cost? (in usa).
15" is needed? three bolt stud holes? (usually, limited to 50 miles.)
better than a can of the fixit spray?
anyone used fixit spray can, on a serious flat? work ok? used the spray type ten years or so ago, seemed it may have inflated, but, dont think i was comfortable about it. something about, its explosive, so, have to disassemble tire and wheel, clean gunk out, or at least the fumes, before re inflating after fixing the problem.
