After having a great talk with 24-42, I purchased the Forge dump valve kit for the 450. I have installed it and will post pictures and video later. For now, lets talk about how to order it.
24-42 told me about a trick someone told him when ordering from Forge. To order anything of Forge's, use
Forge Motorsport (the co.uk site). Upon checking out, in the comments section, tell them you would like the order to be fulfilled by their USA office in Orlando, FL. It adds a couple of days to the arrival of the part, but you can avoid the USD to GBP conversion (brutal right now).
Its a very simple fit, however, if you have the forge intercooler hoses, there is a little bit of a bend added to the top intercooler hose after fitting the dump valve. If you have the ability to cut silicone well, I would suggest trimming a little off of the part of the intercooler hose that connects to the silicone T hose that comes with the dump valve kit.
Also, Forge gives you more than enough of the rubber tubing for connecting the dump valve to the fuel pressure regulator. It really is a very simple install. And its made my shifting smoother when the turbo is going.
Now if I can just get that Brabus steering wheel with the paddle shifters......
