Need help with electrics - 2001 smart for two pure - Smart Car of America Forums : Smart Car Forum
Trailer
Old 10-26-2008, 05:14 AM   #1 (permalink)
Hi, Ive just joined this site. I live in the UK. I have a Smart Car but have a big problem with the electrics. It started with the door locks and lights just constantly locking and unlocking and flashing the indicator lights - perpetually. Eventually I was forced to search for the car battery and disconnect it. When I did so I noticed that the seat well under the carpet is absolutley drenched in water. I need to find where the water gets in, but now when I reconnect the battery the key symbol stays on and the key will not start the car. I assume that water has got into the electronic control system for the locks, but does anyone know where that is located? Also where are the usual water entry points for this model? I have a 2001 smart for two pure. Any help greatly appreciated. Thanks for reading.
dominus is offline   Reply With Quote
Old 10-26-2008, 05:35 AM   #2 (permalink)
Admin/Mod.
It may be the AC drainage. See:
Evaporator Drain Hose Connection
Replacing the drain hose in its intended location could solve the cause.
As for the consequence (flooded electronics) it may require a trip to the Dealer...
Sorry!
Thanks 'Old smart', I too was just going to post Kane's http://evilution.co.uk/
Old 10-26-2008, 05:40 AM   #3 (permalink)
With a 2001 W450 pure (you didn't say if it had air con or not), I would wait for "Evilution" to come online on this site, or contact him directly at: Evilution - Smart Car Encyclopaedia
It is always best to receive the answer here as many others can benefit from the information.
Old 10-26-2008, 11:39 AM   #4 (permalink)
Hi, thanks for replying to my query. The car doesnt have Air conditioning. I have been looking at it this afternoon and identified one area of water ingress on the right hand side rear plastic window. The water seems to be running in there and 'flowing' down toward the front right hand side of the car and the battery well. I am going to get some sikaflex and redo those windows seals. I also noted broken glass fragments under the mat, so at sometime I think either the windscreen or one of the door windows must have been replaced. I still havent managed to locate the electronics that control the central locking mechanism. Does anyone know where these are located as I wonder wether they may be wet. My key is useless now, it doesnt lock the doors or do anything since I reconnected the car battery.
Old 11-06-2008, 05:39 PM   #5 (permalink)
Hello i think the imobiizer for the locks is in the fuse box under dash, it can be removed seperately and leave the fuse box attached, should be a card board panel covering it, maybe the windshield leaked on it!
smart2 is offline   Reply With Quote
Old 11-07-2008, 01:44 AM   #6 (permalink)
Thank you, I will check to see if it is there and/or wet as soon as the rain stops. The car has been out of commision for several weeks now pending the sorting out of this problem.
Old 11-25-2008, 08:54 AM   #7 (permalink)
Just an update, I have got my key working again with the car, but the electrical problem persists. when I conect the battery and press either unlock or lock on the key fob, the locking mechanism just starts toing and froing perpetually, just whirring away, the indicators keep flashing, and it keeps going until the battery runs flat or I disconnect the battery. If I turn the key in the ignition to the 'on' position the problem stops and I can use the car, but it starts again the moment I turn the ignition off.
Help me please!!! I am going nuts trying to locate this problem!
Old 11-25-2008, 09:33 AM   #8 (permalink)
Again, contact Kane at Evilution. He is a "master" with smarts AND he's on YOUR side of the pond!
Old 11-25-2008, 04:08 PM   #9 (permalink)
ASmartMan's Avatar
dominus
chieftmc is correct to a point, Kane of Evilution - Smart Car Encyclopaedia is the out right expert on these cars, and his site offers a lot of info.
Where I have been looking at the SAM (For other reasons) I have read a lot of posts here smartmaniacs home and oddly enough the SAM has been known to get wet, and if it gets wet all sorts of STRANGE stuff could happen.
1st: find the leak and see if that leak has come in contact with the SAM.
2nd: when it goes into its Lock/unlock loop, does opening the door/back hatch/fuel door stop it?
3rd when you connect the battery, if you push the dash board Lock button does it happen
4th: if none of the above change any thing, disconnect this relay http://www.fq101.co.uk/receiver.asp (actually a receiver), if it is still cycling chances are your SAM is damaged (if you found water near the SAM, that could be the cause).
You may be able to hook up with someone close to you from the UK site that may be able to help you quicker than we can.
Best of luck
ASM
ps. it's funny there is a guy in the US (a true micro car lover in Mass.) who has a 2001 cab. and it has the EXACT problem, we've tried to hook up for the last year (so I could see if I could assist) but so far it hasn't worked. SSOO if you find a definite root cause/cure please let me know and I'll pass it on
Old 11-25-2008, 07:12 PM   #10 (permalink)
Drive: Pulse
Yeah, those rear quarter windows are notorious! You might need a new SAM, mate. What part of the country are you in? Maybe we can point you at an indie who can sort it for you.
Bil
electronics, key code issues, leaks
Hello I own a 2001 smart Does anyone know a shop for parts in USA? lfcabrerac New Members Area 3 10-09-2008 06:52 PM
2001 Smart LexLuthor smart General Discussion 4 09-12-2008 02:05 PM
Parts For Smart Passion 2001 Ricardo Archive/obsolete (?) threads 2 08-13-2008 10:06 AM
Interior Parts For Smart Passion 2001 Ricardo Archive/obsolete (?) threads 0 08-13-2008 07:35 AM
my 2001 Brabus Smart Brabus SMART smart Gallery 12 09-13-2007 09:12 PM
