Reset Wrench symbol (450) - Smart Car of America Forums : Smart Car Forum
Old 01-18-2008, 04:04 PM   #1 (permalink)
Don Miller's Avatar
Drive: Pulse
How do I reset the service wrench indicator. I changed the oil now would like to reset.
Don Miller is offline   Reply With Quote
Old 01-18-2008, 04:24 PM   #2 (permalink)
StevenM1TX's Avatar
Ewww, you mean the owner's manual doesn't say?
StevenM1TX is offline   Reply With Quote
Old 01-18-2008, 04:28 PM   #3 (permalink)
Don Miller's Avatar
Drive: Pulse
owners manual
My owners manual is in German I believe. I don't read german. If you do maybe you could answer my question? How do I reset the service symbol for the 2006 Sartfortwo.
Old 01-18-2008, 04:29 PM   #4 (permalink)
Your dealer will do it for a $499 doc fee.
John
Old 01-18-2008, 04:43 PM   #5 (permalink)
Try this to reset service light
This is from the Evilution web site. I do not know if it applies to 451 models.
http://www.evilution.co.uk/index.php...&men=servicing
Old 01-18-2008, 04:44 PM   #6 (permalink)
StevenM1TX's Avatar
My search showed the below methods and it may depend on year. Could try both since it shouldn't hurt at least.
Method 1
Switch on the ignition to position 1
Select maintenance indicator within 4 sec by double tapping the instrument cluster button
Switch of the ignition to position 0 (off) within 10 sec
Push and hold in the instrument cluster button and switch ignition on
Hold the instrument cluster button for another 10sec
In that time, the spanner symbol on the LCD will flash and eventually reset
Method 2
Select maintenance indicator within 4 sec by double tapping the instrument cluster button, keep it held down on the second press.
Switch ignition on
Keep the instrument cluster button held down for another 10sec
Old 06-11-2008, 08:13 AM   #7 (permalink)
p1nball's Avatar
reset@oil change/5800 mi,oil bad!!!
Thnx's<stevenMITX, that tip on how to reset the oil guage works!!! Step one was the cure!!! Oil was really black,but there were no particles in the oil. So thanks for the great info. p1nball!!!!!
Old 06-15-2008, 02:16 PM   #8 (permalink)
jefferios's Avatar
I was told that the Smart Center resets the wrench symbol.
Old 04-12-2009, 01:13 PM   #9 (permalink)
Adjustment to Method 1
Method 1
Method 2
Switch ignition on
Method 1
Make sure wrench is still flashing.
Make sure wrench is still flashing when you turn ignition to position 1 while you
red mnm is offline   Reply With Quote
Old 04-27-2009, 04:15 PM   #10 (permalink)
Thanks, StevenM1TX. Method one for maintenance counter indicator reset worked for me, too. It took me awhile to figure it out. I think the secret is to double tap quickly. Shellcaptain in K.C., MO.
Shellcaptain is offline   Reply With Quote
Maintenance indicator reset (service wrench) robert4600 smart Operation and Maintenance 274 10-27-2011 01:02 PM
Wrench Symbol Don Miller smart Operation and Maintenance 21 04-24-2011 07:20 AM
"Wrench" Symbol goldseekur Original (450) smart fortwo 12 01-02-2010 04:47 PM
Service wrench symbol at 5,000 miles rctcga smart Operation and Maintenance 5 01-04-2009 11:44 AM
How to reset Airgbag light easyware smart General Discussion 5 12-10-2008 07:13 PM
