Originally Posted by cubefx
What do you mean by "liner"?
I see the glove compartment/box as being two items: the door and the liner. The liner is what the aux-in jack (for the Radio 10) is attached to.
Originally Posted by Evilution
The entire dash has to come out to remove the glovebox door frame.
That's what I was afraid that I would discover.
You can remove glove box door in two seconds. There is two big pins at the hinges. I pulled them out without any tools. It is way easier to work inside glove compartment that way.
Sounds like that's the way to go then.
These are the USB bukhead connectors that I will be mounting in the glove box/compartment:
As you can see, I ordered them from pccables.com:
DATA SHEET Part #70552 USB PANEL MOUNT CABLE DUAL PORT BULKHEAD CABLE M-F 3FT
I ordered two of the above (four cable assemblies total) and it cost just over $20 with shipping. They are 3 ft. long with male type A USB connectors at the free end and female type A bulkhead mount connectors at the other -- basically, a USB extension. The male end will plug directly into my Alpine iDA-X100 for attaching my iPod or 32GB thumb drive. Or it can plug into an inverter that provides USB power out.
