The SMART CAR OF AMERICA community is a social utility that connects you with fellow smart enthusiasts.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
I have an 09 with the auto wipers and lights. Do you all think it would be possible to put the wiper/sensor line on a relay that would break the curcate if the key is turned off?
I do not have a wire diagram, so does anyone know if the sensor for the wipers can be put on a relay? the wire that would need the relay would be in the wire that hooks to the wiper selector switch that is closed when the selector is put in auto mode.
Well, If you leave the auto headlights in auto ( which I Do) everything is fine. if you leave the headlights set to auto and the wipers set to auto ( which happens if you are driving on a rainy day and forget to turn them off when you get home because it was not raining at the time )the battery slowly drains and the car will not start. This relay would only let the wipers stay set to auto if the key is on.
Funny, on my '08, I never use the auto headlights, but regularly forget to turn off the auto wipers. Sometimes they're on for days and I've never had a problem with battery drain, even before the 2.0 upgrade.
My battery only goes down if both are left on. And the first time it happened was after a flash for the fuel gage 7/8 thing. I am in the process of installing charging ( Jumping) studs under the front hood.
i have both features in my car (comf package). i leave them in the auto position more often than not. I have let it sit for 4 months with both features on, and no problem with a drained battery.... and thats after the battery/bridge recall. i am assuming that because u have the '09, u have the 2.0 flash?
A patch for the battery drain issue came out earlier this year. You should see your dealer.
