BP Air Scoop and Fuel Lid - Carbon Fiber - Smart Car of America Forums : Smart Car Forum
Trailer
Old 07-24-2008, 10:35 AM   #1 (permalink)
SeCrEt AsIaN MaN
tigerwong58's Avatar
Just received from Breathless Products the Carbon Fiber Air Scoop and the Carbon Fiber Gas Lid. Both look very good. The Air Scoop had a line of bubbles through it and the gas lid has tiny bubbles around the visible edge, doesn't show good. I emailed Ernie and he said he would replace it. The inside of the scoop is visible when attached, it would be nice to have a better finish inside also. I am going to sand mine a little smoother inside and paint it black. Right now it looks like dark gray bondo. The Gas Lid is not easy to glue and align, it came it a tube of GOOP adhesive which runs when trying to attach the gas lid. I am going to try another approach.
Old 07-24-2008, 10:50 AM   #2 (permalink)
brian r's Avatar
Goop is junk. Get a roll of 3M molding attachment tape. Run it around the edge of the cover, put a small square in the center, and put it in place. The tape is grey, so even though it's thin, you might want to run a permanent black marker over the edge before attaching it. You can use dental floss to remove it if you ever need to.
Old 07-24-2008, 10:59 AM   #3 (permalink)
SeCrEt AsIaN MaN
Tape will not work for the Gas Lid. You have to remove the factory lid and glue it to the waffled plastic rectangle. Tape only works on flat surfaces.
Old 07-24-2008, 11:16 AM   #4 (permalink)
brian r's Avatar
I thought it was just a CF cover applies to the entire OEM door . My bad.
Old 07-26-2008, 04:17 PM   #5 (permalink)
Actually you do not need to put to much goop on the gas door. Just a little on both sides and use masking tape in a cross pattern to hold it in place. If done right you will not have any leaking down.
Ernie
Old 07-27-2008, 12:29 AM   #6 (permalink)
mendo's Avatar
My Scoop was Great!
looks great too!
Old 07-31-2008, 12:19 PM   #7 (permalink)
Thank you, glad you loved it.
Ernie
Old 08-05-2008, 10:09 AM   #8 (permalink)
SeCrEt AsIaN MaN
I decided to send both of mine back to BPP for a refund. I'll wait until their product is bubbleless.
Interior carbon fiber pieces? SunDiego smart Modifications 18 03-24-2009 10:30 PM
Rear Carbon Fiber/Chrome Lettering plate BreathlessPerformance Interior & Exterior Styling 10 02-24-2009 07:53 PM
New Cold Ram Air Intake Scoop Just Out.. BreathlessPerformance Interior & Exterior Styling 62 02-23-2009 09:52 PM
Carbon Fiber Thrilla from Manila Interior & Exterior 21 09-15-2008 07:06 PM
New Rear carbon Fiber/ Chrome Lettering Plate BreathlessPerformance Interior & Exterior 0 05-29-2008 03:27 PM
