Old 06-15-2008, 08:31 PM   #1 (permalink)
Lgaruti's Avatar
Drive: Brabus,Passion Ford GT,DB9
BPP Center Exit Exhaust too loud? Here’s a mod.
I like the look of the BPP center exhaust but found it a bit too loud for every day driving. I measured 94db four feet back from the exhaust and 90 db in the cabin at idle. 50 mph the cabin varied between 92 – 96 db noise level (road noise + exhaust). Just too much for me.
After the mod. the cabin measured 84 – 86 db and the exhaust four feet back at idle was 92 db. It still sounds great but not overly loud.
Gas mileage and performance is yet unknown as the inserts do add some backpressure. The smart seems to have a little more bottom end and less top end over 6000 rpm.
Here’s the mod:
Purchase (2) 4” long exhaust baffles for a 2” motorcycle exhaust pipe. They are available via the internet and cycle shops.
Purchase (2) 1 ¾ id to 2”od exhaust adaptors. I got mine at AutoZone. see pic.
If you can find a baffle for a 2 1/8” pipe the adaptor is not need.
Slide the baffle into the adaptor. The baffle has a ¼” mounting hole. Mark this hole on the adaptor and drill a ¼”. Place the baffle into the adaptor and line up the mounting holes.
Insert the adaptor & baffle assembly into the exhaust tip with the mounting hole down and place a mark on the underside of the tip corresponding to the mounting hole in the adaptor. I used a bent paperclip placing one end in the adaptor hole and the other marked the drill point.
Drill a ¼” hole in the bottom of the twin tip outlet. Center punch then start with the smallest bit possible and work up to ¼”. The tip is double walled so take your time.
Re install the assembly, insert the bolt that came with the baffle and secure with lock washer and nut.
Lgaruti is offline   Reply With Quote
Old 06-16-2008, 06:55 AM   #2 (permalink)
geosynch's Avatar
Drive: 2008 smart Cabriolet
Did you have the sport or touring version?
Old 06-16-2008, 01:02 PM   #3 (permalink)
Lgaruti's Avatar
Sport version...
Old 06-17-2008, 10:28 AM   #4 (permalink)
Supporting Vendor
Drive: Corvette Z06, Smart + More
I like the mod very ingenious.
However you can always purchase the touring version instead of the sport.
Ernie
__________________
Breathless Performance Products
For Smart Performance
www.BreathlessPerformance.com
954-925-7725
Old 06-17-2008, 08:14 PM   #5 (permalink)
Lgaruti's Avatar
Ernie
Ernie, How much quieter is the touring version? Larry
Old 07-04-2008, 10:15 AM   #6 (permalink)
SylenThunder's Avatar
Drive: Smart Passion Coupe
I seem to recall reading somewhere that the touring version is in the 60's, but don't recall exactly. It was either that or about 60% louder than stock. IIRC
Old 07-08-2008, 05:03 PM   #7 (permalink)
Supporting Vendor
Now about 20% quieter
Ernie
__________________
954-925-7725
Old 07-08-2008, 05:43 PM   #8 (permalink)
Broken Kid's Avatar
Drive: Red/black Passion
Since getting the sport version, I'll say this - the only time I thought it was a little too loud was when pulling into a church parking lot. Every other time, I think it sounds great, and everyone who hears it really likes it. No, it doesn't wake the neighbors!
Broken Kid is offline   Reply With Quote
Old 08-10-2008, 11:56 AM   #9 (permalink)
Drive: Passion Coupe
BPP
Ernie
Hey ernie, is there really a 20% decrease in sound? on your site it still says 12%
"Available in Sport Version or Touring ( a little quieter 12 percent)"
bjchism1 is offline   Reply With Quote
Old 08-10-2008, 04:55 PM   #10 (permalink)
geosynch's Avatar
I should be getting my touring version tomorrow. I'm a little nervous it'll be too loud, as there have been complaints about the touring version as well.
What I'd like to know is, how is the 12% (or 20%) quieter measured? Typically sound is measured in decibels, which are logarithmic. 80 db v. 90 db is 10 db quieter, which means it is 10 times quieter, not 11% (90-80)/90 taken as a percent. 3db quieter is a reduction of 50%.
A true 12% (or even 20%) reduction would be less than 1 db. One db is about the limit of most peoples ability to perceive a difference.
So, if the sport and touring versions have been measured by a db meter, I'd love to know the results.
geosynch
1 day left on the special buy price of Breathless CES Performance Center Tip Exhaust BreathlessPerformance Performance & Handling 13 02-21-2009 03:30 PM
New Kuhl-FX with Center Exhaust Carlssonpro Interior & Exterior Styling 10 07-25-2008 10:05 PM
Evil Center Exit Exhaust 16d @ 4 Smart Car Modifications 6 06-16-2008 10:07 AM
2 weeks away from pics of our center tip exhaust system and custom lower Valance BreathlessPerformance Performance & Handling 4 05-18-2008 06:30 PM
What is the loud Whine when starting cold? redbluff Smart Car Operation and Maintenance 12 04-07-2008 11:41 PM
