Brabus Instrument Cluster and Steering Wheel - Smart Car Forums
post #1 of 26 (permalink) Old 05-11-2010, 12:42 PM Thread Starter
OK here is the deal....I just purchased a black face Brabus instrument cluster and black pods from a vendor in the UK. I've installed the pods already but, have held off on the instrument cluster. The installation on the cluster looks to be straight forward... Basically a plug and play but, my question is...
Will the correct odometer reading show up on my new cluster once installed or must the mileage be programed into it with a scan tool. I am an ASE Master Tech and can easily swap the cluster but, I don't have access to the Daimler/Mercedes scan tool to program in the mileage. I really do not want to take it to the dealer... I'm not cheap! I just like to do my own work
Also, Is the steering wheel an issue as well. The car is a US spec Brabus and has the paddles on the wheel already so, I figure I should not have to program for the European market Brabus wheel... I assume it is a straight remove and replace.
I hope one of you guys on here works at a Mercedes or Smart Dealership and can help me out with this..
If the cluster and wheel have to be programed is the dealer my only option?
Thanks in advance for any and all help you folks can give me.
Jim
BlackBrabus5339 is offline
post #2 of 26 (permalink) Old 05-11-2010, 12:57 PM
Good question... I don't know the answer but it takes all of a minute to swap the cluster (no screws, just pop it out and pop off the wiring connector), why not just try it?
fredthe is offline
post #3 of 26 (permalink) Old 05-11-2010, 04:07 PM Thread Starter
I guess I could try it but, my concern is if I plug it up and the mileage does not transfer will it cause an issue with the PCM. It may see my new cluster as an attempt to tamper with the mileage and set a code or go into a lock out mode.
Since I don't know how the system is set up I'm scared to try it .
post #4 of 26 (permalink) Old 05-11-2010, 05:54 PM
Quoted: 7 Post(s)
Can't you just swap out the guts of the two clusters
http://www.smartcarofamerica.com/for...edo-diy-22913/
forestacademy is offline
post #5 of 26 (permalink) Old 05-11-2010, 07:25 PM Thread Starter
The Brabus cluster cost me almost $300.00 shipped. I'd rather not start swapping guts and possibly end up with 2 dead clusters.
post #6 of 26 (permalink) Old 05-11-2010, 07:49 PM
Brabus007's Avatar
Quoted: 83 Post(s)
Your cars computer keeps your Miles driven INFO... Its plug and play... Just swap it out...
Brabus007 is offline
post #7 of 26 (permalink) Old 05-11-2010, 07:52 PM
Quoted: 145 Post(s)
...I believe somebody did this and the display was in KPH...and the dealer will not even touch it ...
jetfuel...proven wrong before..
jetfuel is offline
post #8 of 26 (permalink) Old 05-11-2010, 08:38 PM
Brabus007's Avatar
Quoted: 83 Post(s)
As seen in the Link... You do need to order the right one...YUP
Smart Parts Direct Limited 451 Interior - Instruments
post #9 of 26 (permalink) Old 05-11-2010, 08:40 PM
It needs to be programmed by the dealer, (The vehicles VIN has to be entered) Been there done that already!
IH8OPEC is offline
post #10 of 26 (permalink) Old 05-11-2010, 08:53 PM
Supporting Vendor
Quoted: 6 Post(s)
The miles are in the SAM. The coupling of the instrument cluster is also in the SAM. No plug & play - it needs serious dealer intervention.
Good luck with that!
John_H is offline
Human Verification
331
Strange 450 instrument cluster? jwight Original (450) smart fortwo 11 09-15-2010 09:25 AM
Instrument cluster question donnyonee Interior & Exterior 3 04-09-2010 06:34 PM
Instrument cluster symbols mcdonaldroadcapt smart General Discussion 1 02-23-2010 01:03 PM
Instrument cluster (Re: readability) tablepad smart General Discussion 12 08-08-2009 09:50 AM
Instrument Cluster Display Problem factor9 smart Operation and Maintenance 6 05-03-2008 10:14 AM
