Central Electronics Question: Retrofitting European tail lamps - Smart Car of America Forums : Smart Car Forum
Old 08-27-2009, 01:18 PM   #1 (permalink)
The NA spec Smart ForTwo has one drawback, the singular brake lamps/parking lamps/turn signals...
so Smart Techs, this is a question for you!
Can the NA spec ForTwo central electronics unit be re-programmed to use the european tail lamps? Is the wiring there, ect?
These are the units that have amber turn signals and rear fog lamp on the drivers side:
If this is possible, can we get part numbers for the ROW/EU tail lamps and ROW switch unit that has the rear fog lamp switch?
kevster03 is offline   Reply With Quote
Old 08-27-2009, 02:01 PM   #2 (permalink)
I can tell you right off the bat that the rear fog lamp button has no wire in the wiring harness. If you pull out your center button console, remove the connector, then take the white shield off the retained black connector, you'll see there's nothing loaded for pin #9 in the harness.
So how much farther do you want to go? Is it a deal breaker?
Old 08-27-2009, 02:13 PM   #3 (permalink)
Old 08-27-2009, 02:16 PM   #4 (permalink)
edit: i am a moron apparently sorry for the repost
Old 08-27-2009, 02:43 PM   #5 (permalink)
wiltjk's Avatar
My wife has a unique ability to point things like this out to me so that I am in the same place as you. I have come come up with a fairly decent response:
Well, I may be a moron, but at least I didn't marry one!
wiltjk is offline   Reply With Quote
eletronics, mods, tail lights
Hoping for a favour from a European 451 owner (Re: tail lights) Padawan SCOA International 18 04-25-2011 05:59 PM
Hoping for a favour from a European 451 owner (re: Euro tail lights) Padawan smart General Discussion 21 01-12-2009 08:40 PM
Where can I order a set of European 451 tail lights? Padawan smart Modifications 6 12-09-2008 08:10 PM
Retrofitting parts from Passion to Pure... Eric H. smart General Discussion 12 09-03-2008 07:21 PM
Want a key without all the electronics on it Convert New Members Area 5 07-27-2008 04:40 PM
