Originally Posted by TMACK
Smart bloody idea. I was planning something along the same line, glad you paved the way.
Are you going to provide any more installation details? How did you mount the terminals? What did you use for terminals?
Yes. the terminals are from a auto racing store on line. Also E-bay. The brackets I made myself and I mounted them on the cross member by drilling a hole. The positive terminal needs to be mounted in a way not to hit anything that would ground it out.
the negative was easy since no precautions were needed ( no short worry) the wire is awg 6.
The reason they are so big is to have a easy point for a positive jump cable. The last thing you want is a hard to connect post with grounding spots every place.
I might put together a package and try to sell them. To non members via E-bay or here if you all think it would work. I see it as a needed option for the car.
