Originally Posted by Smart Enuf
The noise and other issues aside, in the summer you're going to cool your cabin air anyway with your A/C, so why couldn't you use that cooler air rather than the outside air?
Smart Enuf - as stated, there are several problems with using the cabin air over outside air:
1. In order to prevent yourself from driving in a vacuum, you would need to either draw hot air through the A/C, rather than re-circ, which make the A/C far less efficient, or you would need to keep a window cracked open, drawing hot air into the car;
2. Regardless of how the air gets into the cabin to replace what goes through the engine, the added flow will cause the A/C (which is driven by a thermostat) to have to work harder to cool the air, thus causing a heavier drag on the engine, thus causing the engine to work harder, thus reducing your MPG and available power more...
In the long run, the cool air from inside your cabin will cause you to spend more than the hot air already available outside...
