Old 03-08-2009, 08:33 AM   #1 (permalink)
Which Dealers can Activate Fog Lights?
Which dealers (or shops) can activate the Fog Lights feature by applying the TAN code? If you put the effort in to install the physical fog lights hardware, you need to know who can activate them. You don't want to drive around with inoperable fog lights. If you have them, you want to use them. Most dealers say they can't or aren't interested in doing the activation. Help out by telling us where they can be activated. Thanks.
charlie42 is offline   Reply With Quote
Old 03-08-2009, 09:24 AM   #2 (permalink)
Drive: smart S/S cabriolet
I had mine activated in Lynnfield, Mass.
Little John is offline   Reply With Quote
Old 03-08-2009, 10:38 AM   #3 (permalink)
Brabus's Avatar
Drive: 2009 Smart Brabus Cabrio
I have two Smart cars. Yesterday, I swapped factory fog lights from one Smart car to my Brabus. To my surprise, the Brabus had the wiring for the fog lights so it was a simple swap. However, they don't turn on.
I thought to myself that there must be a relay, fuse or some sort of switch or wiring mechanism to make them work. After reading this post it seems there is a computer activation that only dealers can do?
Old 03-08-2009, 11:18 AM   #4 (permalink)
Brabus's Avatar
Originally Posted by erothstein View Post
At Al & Eds Autosound in West Hollywood we install the original fog lights and wire them to turn on when the headlights are activated.
I'd drive down there but I'm in Connecticut.
Any tips on wiring?
Also, just out of curiosity, how much does it cost to install the original fog lights?
I was hoping to have them work with the Fog Light button that is next to the hazard light button.
Old 03-08-2009, 11:38 AM   #5 (permalink)
chasingrabbits's Avatar
Drive: 08 Passion76 Mini PanelVan
in leu of getting the computer activated you could still use the fog light switch with some wiring modifications. You could purchase a small relay to handle the load. The fog light switch could be re-wired to turn on the relay which would then send power to the fog lights. This is essentially what the computer does internally. This is a lot of trouble so the first choice would be to try and get the computer programmed.
chasingrabbits is offline   Reply With Quote
Old 03-08-2009, 12:38 PM   #6 (permalink)
Brabus's Avatar
Agreed. So when the computer is programmed, will that activate the fog light button next to the hazard light button. I wanted to just swap that control unit of buttons between the Smarts or does this computer programming just work to turn on the fog lights on with the headlight switch?
I'll check with White Plains, NY, Hartford & Fairfield, CT dealers tomorrow to see if they will do such. I might be driving up to Mass.
Or is there a device I can use to activate it myself?
Old 03-08-2009, 10:32 PM   #7 (permalink)
spdickey's Avatar
Drive: smart passion coupe
Here are the instructions for fog light installation Evilution - Smart Car Encyclopaedia
Old 03-12-2009, 08:54 AM   #8 (permalink)
Smart09's Avatar
Any luck. My dealer said it cannot be done. Sucks
Smart09 is offline   Reply With Quote
Old 03-12-2009, 09:56 AM   #9 (permalink)
Smart09's Avatar
I spoke to my other dealer and to activate the fogsits 60 dollars and then they say I have to buy the whole piece were the buttons
Are for 125. Can't I just do the mod evilutions had and make a button?
Old 03-12-2009, 12:08 PM   #10 (permalink)
Smart09,
What is the name and location of the dealer who will activate the fog lights for $60?
Fog lights spliced into parking lights patbianchi Interior & Exterior 36 11-16-2009 05:02 PM
US Dealers ASmartMan Dealers and Parts 8 06-23-2009 12:22 PM
Key Fob Will Not De-activate Immobilizer Dukester Smart Car Operation and Maintenance 5 07-20-2008 05:45 PM
Known 450 Dealers ASmartMan Dealers and Parts 0 02-22-2008 09:38 AM
More Dealers rwj53 Mid-West Region 2 01-30-2008 10:13 PM
