DIY cargo Shelf - Smart Car of America Forums : Smart Car Forum
Old 05-12-2009, 03:07 PM   #1 (permalink)
JimDantin's Avatar
DIY cargo Shelf
I've been needing a rigid cargo shelf for my dogs and other things. I wanted a level, carpeted area that could be installed and removed without tools, and could be stored behind the driver's seat when not in use.
I made it from a piece of 1/2" plywood (18" x 48"), a length of piano hinge, a rug, and some miscellaneous hardware. Descriptive pictures can be found here:
Cargo Shelf
I made a set of templates to help you cut the plywood to fit the car. The templates are four PDF files -- two for the right edge and two for the left edge. You tape together the two sides, and then tape to the ends of a piece of plywood.
Download the templates (Shelf1.pdf through Shelf4.pdf) from here:
http://personalpages.bellsouth.net/j/d/jdantin/files/
The piano hinge is 1.5" wide. Cut it to the 18" length of the shelf, screw it down, mark the centerline, remove the hinge, cut the shelf in half along the centerline, and then reattach the hinge.
The center support is a piece of scrap 3/4" wood -- I had a 2" wide piece, but anything up to a 1x4 should work.
I wanted the shelf to stay in place, but be removable without tools. I had some spare shelf supports that worked perfectly. I also added some velcro and pieces of rigid foam to the support brace to prevent rattles.
If you want more legroom, just make it shorter -- anything from 12" to 18" should work fine.
Look at the pictures and descriptive comments. If you have questions, just ask, or see me at the Indy Speedway on May 20!
Old 05-12-2009, 06:48 PM   #2 (permalink)
driven2succeed's Avatar
Very Nice! I'll find you at the Indy event!
driven2succeed is offline   Reply With Quote
Old 05-12-2009, 08:11 PM   #3 (permalink)
Owner for 3.8 years
Kermit's Avatar
That looks GREAT! Good job!!
Old 05-13-2009, 07:45 AM   #4 (permalink)
Thanks Jim
Exactly what I've been looking for (I use the same ROLA)
Old 05-13-2009, 09:45 AM   #5 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
I copied the pdf files and will check them out. I found this jpeg file at the site and thought it was funny.
Old 05-13-2009, 11:33 AM   #6 (permalink)
JimDantin's Avatar
You can get one on Ebay!
Old 05-13-2009, 11:40 AM   #7 (permalink)
JimDantin's Avatar
Don't hesitate to ask questions -- the templates are pretty rough and hard to explain, but should do the job. Two on the left, two on the right, nothing in the middle.
Old 05-28-2009, 10:30 PM   #8 (permalink)
caroniaguy's Avatar
Just tried this mod and it worked out beautifully. Thanks Jim for the idea and the templates. I have almost zero construction skills and this turned out great! Easy and worthwhile, not to mention this cost me only $12 dollars compared to $149 for the official cover.
caroniaguy is offline   Reply With Quote
Old 05-29-2009, 05:21 AM   #9 (permalink)
JimDantin's Avatar
Welcome to the "I made that" club! I love DIY projects that save money and provide a functionality that exceeds commercial alternatives.
Let's see some pictures!
Old 05-29-2009, 08:26 AM   #10 (permalink)
Please ignore the man behind the curtain.
Last edited by John_H; 05-29-2009 at 08:51 AM. Reason: wasn't paying attention to *who* was talking
cargo, diy, shelf
Secret shelf! Any other secrets? unicycle smart General Discussion 21 11-29-2009 10:57 PM
Cargo box for under $20.......... smartiealbert smart Operation and Maintenance 2 12-29-2008 05:46 AM
Cargo pod john Riley Interior & Exterior 5 10-13-2008 06:11 PM
Boot/Luggage area cover-shelf EdwardDennis smart Modifications 10 06-29-2008 09:15 AM
