Electronic flasher for LED flashers - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 07-06-2009, 11:42 AM   #11 (permalink)
LittoDeviL's Avatar
Originally Posted by John_H View Post
It doesn't take many 1W chips to provide the equivalent of a 20W incandecent.
Absolutely correct, both CREE and LumiLeds both create 1 watt led's. Run them at 350ma and the right optics, you'll use less but still need to mount them on a heat sink to get rid of the heat that it does generate but yea.. those are the proper led's to use.
Larry
LittoDeviL is offline   Reply With Quote
Old 07-07-2009, 02:47 PM   #12 (permalink)
SmartDigger's Avatar
So, anyone know where the flasher box is?
Old 07-07-2009, 03:35 PM   #13 (permalink)
The relays are plugged into the back section of the SAM. I have pictures in the directory somesmart.info/RandomImages/Relays showing the SAM (Relays.jpg) from the left heel view - you can see the carpet runner for orientation - as well as photos of the relay itself. The position pointed to on the SAM is where the relay was removed. Even though it's the rightmost relay, it appears to control the left turn signal.
Old 07-07-2009, 07:19 PM   #14 (permalink)
Thanks. that is what I was hoping to see.
Old 07-07-2009, 08:12 PM   #15 (permalink)
I searched but did not find a cross part for a no load relay. Might try the auto parts store tomorrow. Anyone know of one?
Old 04-21-2010, 09:36 PM   #16 (permalink)
still looking
Turn Signal / Flasher Problem lunarx smart Operation and Maintenance 9 09-07-2011 06:15 PM
Turn signal flasher problem smartdog smart Operation and Maintenance 5 05-10-2009 12:09 AM
CounterAct electronic rust protection f6hlct smart Operation and Maintenance 19 12-14-2008 09:36 PM
RF/Electronic inteference KingNine smart Operation and Maintenance 1 03-19-2008 10:26 PM
Electronic Performance Mod's? doc540 smart Modifications 6 01-31-2008 07:06 AM
