You asked Wdhitch but I'll add my perspective.
If you want to see the LED behind the second switch on the left (as viewed from the front) you need a hole or a clean scraped or dremeled region. The image below shows where LED windows already exist for the heated seats (2 per switch, outside), lock (furthest inside), and alarm as well as where the fog light window is intended to be. The rubber membrane that holds the switch pads also surrounds each LED so you don't need (or want, really) a light pipe as much as a nice front surface to show the light.
Personally, I'd appreciate making the buttons available without having to replace the entire &#$% button bank assembly.
