Fog light indicator - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 06-03-2009, 04:18 PM   #11 (permalink)
banned
It's not on all the time... it's just the back ground illumination for the button bank... it comes on with the parking lights...
Old 06-03-2009, 06:51 PM   #12 (permalink)
For sale pm for details
Turbo42's Avatar
Mine was moded and my light does not stay on
Old 06-03-2009, 09:23 PM   #13 (permalink)
So the window for the LED should be on the bottom half of the button, not the top half. The top half is where the small lights-illuminated backlight LED goes. The main LED on the bottom half is where the indicator window should be.
You scraped a window in the bottom, got the TAN code flash, your fog lights turn on, but you don't get any bright illumination there when you turn on your lamps?
Old 06-08-2009, 12:04 PM   #14 (permalink)
banned
So I finally figured out what the hell was going on. My drilled indentation to the button was too high... so it only picked up the background amber LED... a lower drill and the green button now works as it should.
JohnH... if you look at the left side of the speedo 3rd slot down below the high beam indicator it looks like that could be a foglight indicator... any thoughts?
Old 06-08-2009, 12:25 PM   #15 (permalink)
Padawan's Avatar
That's the rear fog lamp indicator. ECE regulations require the rear fog lamp to have an indicator light that is easily visible to the driver, so that it is not accidentally left on or used when it isn't needed.
Old 06-08-2009, 12:25 PM   #16 (permalink)
Wdhitch - that's what I was telling you earlier. Check out response #3 in this thread where I even show a tiny (actual) picture of the indicator. While I think it's intended for the rear fog light which isn't available in the US, I could put together a tiny LED board to go on that side of the instrument panel just like I did for the cruise control.
I'll be probing soon thanks to some spare wires from brett2658 that should show up in a day or two. (I so prefer to do my probing without harming the existing wires.)
Has everyone who has done their own foglights had them enabled at the dealer? If not, how does one enable them? I'm thinking I'd need the code to get different behavior on my own unused foglamp switch.
Old 06-08-2009, 12:37 PM   #17 (permalink)
brett2658's Avatar
Fog light hole fix
3m makes a clear universal adhesive part # 8217. When you drill the hole and tape the outside, you might be able to fill the newly drilled hole to make a "clear window" like the factory switch. I have cut the tabs off and was at a stand still about the light hole. If somebody wants to send there switch after you have drilled the hole i will fill the hole with 3m product since it is about $40.00 a tube and a $350. Gun to mix it i have all of it. PM ME IF YOU LIKE TO TRY IT!
brett2658 is offline   Reply With Quote
Old 06-08-2009, 01:24 PM   #18 (permalink)
banned
John... if you comeup with a solution let me know... I'll be the first in line.
On the enabling issue... I had mine turned on before I secured the lights themselves... I think you could have them enabled and then just clip off the stock hookups and use the existing wiring... can't see why it wouldn't work.
Brett... The buttons are quite thick... I only had to drill a couple of mm to get to the opaque (sp?) part... didn't have to drill all the way through.
Old 06-08-2009, 02:11 PM   #19 (permalink)
I could have the fog lights enabled (without actually having the lamps) but what do I have to do to enable them?
Wdhitch - what color would you like for the instrument cluster fog lamp indicator? The headlight indicator above is green, the high beam indicator below is blue. You'd have two cables going into your cluster now, not just the one for the Area451 CC. I'll use the same cable type but swap the direction (male/female sides) so you know which cable is which.
Old 06-08-2009, 04:53 PM   #20 (permalink)
banned
Blue is fine... same as the cruise. Thanks for working out the details... I'm not electronically inclined.
To get them activated I'm guessing you'd need the code... the tech hooked up the computer to the car to activate them.
SRS Indicator Light SmartCab08 smart General Discussion 47 10-25-2011 06:08 PM
Tail Light & Brake Light Problems smartass1 smart General Discussion 6 09-05-2010 10:30 AM
Resetting the indicator Speedy New Members Area 2 02-01-2009 12:43 PM
Front passenger indicator light out terrapin smart Operation and Maintenance 2 12-04-2008 05:39 AM
