Fog lights spliced into parking lights - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 06-21-2008, 09:37 PM   #21 (permalink)
Originally Posted by Evilution View Post
Yeah but foglights, the clue is in the name.
In the USA most owners provide there own fog and proudly show off all the lamps they paid for including the rear fog lights in all weather. Dam fool lights more like it.
Old 06-23-2008, 04:14 PM   #22 (permalink)
Happy Happy..... )
patbianchi is offline   Reply With Quote
Old 06-27-2008, 02:16 PM   #23 (permalink)
lowndex's Avatar
Which wires to tie together?
Originally Posted by patbianchi View Post
For the simple minded like me here is a diagram for the wiring> Fog Light Wiring with Bosch Relay
The wires going to the right fog light are brown (is this ground?) and yellow-grey (is the hot?). The left fog light has the same brown/yellow-grey pair with an additional pair of purple/brown wires.
The wiring diagram instructs to tie the hot wires of each fog light together and wire to Post 87 on the Bosch relay. Which pairs of fog light wires are hot: yellow-grey, brown or purple?
Old 06-27-2008, 02:19 PM   #24 (permalink)
lowndex's Avatar
Got a wiring diagram, please?
Originally Posted by Dunerunner View Post
I would add a relay and smart panel switch then run the power lead directly from a spare fuse in the fuse block. No SAM programming needed!!
Even hand drawn?
Old 06-27-2008, 03:03 PM   #25 (permalink)
Without the lights, I cannot say what the two pair of wires are on the left fog light but I have heard Evilution say Brown is ground. Hook them up outside the car (unmounted) and test the operation. I am guessing the extra pair of wires on the left could be for a "Fog lights on" monitor for the SRM or ECU. It could also be just a lighted indicator run. Use an ohmmeter to measure between the yellow/grey and pruple wire. If my guess is right they should be internally connected in the lamp housing. If that is the case, when wired up to a voltage source, the purple wire will become a floating hot lead. You now have the choice of lighting the switch when the fogs are on or securing the purple and brown pair so they do not short to ground. (Lots of tape to make water tight)!! Hope this helps. After you do this, we'll worry about wiring the switch to the relay, relay to the lights.
Old 06-27-2008, 03:24 PM   #26 (permalink)
There's a stack of brown wires on a ground bolt inside the left rear trunk panel.
Old 06-27-2008, 03:31 PM   #27 (permalink)
lowndex's Avatar
I do not want to wait on Smart SRM
I want the fog lights to come on when the head lights do - no switch used. I did a search on the net for an associated wiring diagram. I found good advice on tying into the hot wire of the right or left side lights. The side/blinker lights come on with the headlights.
Old 06-27-2008, 04:12 PM   #28 (permalink)
Drive the fog relay with the + Battery from the headlight switch. Tie the contacts of the fog relay to the fog lights. Fuse both runs (to the relay Fuse 1 and to the fogs Fuse 2). You can omit the switch in the schematic as you are driving the relay coil with the headlamp switch.
Old 06-27-2008, 06:14 PM   #29 (permalink)
lowndex's Avatar
Smart fog lights without SAM or switches
The pictures below are meant to serve as examples only.
I am tying into the hot wire of the side/blinker lights, which are always powered when the headlights are powered. To that end, I am utilizing the headlight switch.
I tie both of the fog light positive terminals (hot) together and wire into the Bosch relay post 87.
I am using a 25 amp fuse from the Bosch relay, post 30, to the positive terminal of the battery. I am using 12 gauge wire for this length of wire.
I am taping the positive wire of the side/blinker lights and connecting that wire to Bosch delay post 85. Thus, I need no switch.
Essentially, I am using the wiring diagram below but with no switch.
Old 06-27-2008, 07:35 PM   #30 (permalink)
Perfect, I still would fuse the + Batt lead from the side lights you are using to drive the relay. Otherwise it should perform well!!! Congrats!
After market fog lights? patbianchi Interior & Exterior 17 08-09-2008 02:06 AM
Anyone add on the fog lights? farkas Interior & Exterior 4 04-28-2008 12:12 PM
Running lights ( again ) 4-2NV Interior & Exterior 8 04-03-2008 09:54 PM
Bright Lights! SBibbo smart General Discussion 8 03-07-2008 01:41 PM
When to use fog lights Karl Roth smart General Discussion 56 02-01-2008 12:53 PM
