Handbrake handle - Smart Car of America Forums : Smart Car Forum
Old 10-10-2009, 09:35 AM   #1 (permalink)
nonuro's Avatar
Handbrake handle
I have made a gater cover in red Ultrasuede but can't figure out how to get the handbrake handle off.Any ideas?
Old 10-10-2009, 09:55 AM   #2 (permalink)
Padawan's Avatar
Remove hand brake cover
Depending upon whether you have the old or new style handle, you may or may not be able to remove it without destroying it in the process.
Old 10-10-2009, 10:08 AM   #3 (permalink)
Supporting Vendor
SmartMadness's Avatar
If you have a 2008 model it will be easy. Look under the handle and you will see a round cap. Pull out the little cover/cap. Unscrew the knob and slide off the handle.
If you do not have a cap under the handle and have a 2009 model (it could also be a late 2008) then the only way to get it off is with a dremel tool and then replacing it.
If you need help give us a buzz and we'll help you out a bit over the phone. I will be at the shop 10-4 (pacific) today. 562-961-6800.
Boris
__________________
Old 10-10-2009, 10:34 AM   #4 (permalink)
JOIN SCOA.YOU'LL BE GLAD
..the 08 and 09 we have had the same set up...no locking screw...unscrew the push button...I used an adjustable wrench with the jaws covered in tape to prevent scoring/scratching the metal part...place over the metal part and use a small mallet (or a very large hammer .. J/K) to drive the plastic out of the shank.....
jetfuel...BTDTRT
Old 10-10-2009, 08:12 PM   #5 (permalink)
Owner for 3.8 years
Kermit's Avatar
OK nonuro. Lets see a pic of the finished product.
Old 10-10-2009, 09:55 PM   #6 (permalink)
nonuro's Avatar
I got the button off,an easy twist and off it came.Now the grip------I don't have the strengh in my hands to pull it off so is that where the vise grips and mallet come into play?
Jet-could you post a pic of where you put the wrench?
Old 10-10-2009, 10:07 PM   #7 (permalink)
...I will not use anything that has teeth or serrated jaws like vise grip pliers...and adjustable/crescent wrench is more suitable for the job 'cause it will leave no marks..
tape the jaws or place some kind of protection over the round portion of the handle right behind the rubber piece ( a towel come to mind )..and mallet away forward with gentle force (oxymoron)...after a few blows it will be easier to move ..wd40 sprayed inside the handle will make it slide off too
jetfuel...hope this helps
Old 10-10-2009, 10:46 PM   #8 (permalink)
nonuro's Avatar
I'll give it a try tomorrow.
Old 10-10-2009, 10:52 PM   #9 (permalink)
Be sure you got out the plastic rivet. Here's a pic of what the one on my '08 looked like, that may help you visualize what you're doing.
Old 10-10-2009, 11:02 PM   #10 (permalink)
nonuro's Avatar
Thanks for showing me that pin.I felt around the handle but didn't feel anything but know I know where to look.If it matters,the build date of my car is 4/2008.I'll post a pic when I get this mod finished.
Door Handle Removal??? rayman1946 Original (450) smart fortwo 4 07-05-2009 05:02 PM
Oil smell & Heat through Handbrake area n5yn5y smart General Discussion 20 04-17-2009 09:42 PM
Aftermarket Handbrake options? akiranakayama Interior & Exterior 11 10-09-2008 09:51 AM
How does the car handle the wind? The Dude smart General Discussion 2 11-21-2007 03:45 PM
How Will New Smart Handle uncletony smart General Discussion 3 11-05-2007 07:54 PM
