I have "Brabus ambient lighting" but don't have... - Smart Car of America Forums : Smart Car Forum
Trailer
Old 08-15-2009, 05:55 AM   #1 (permalink)
I have "Brabus ambient lighting" but don't have the instruction.
Does anyone know how to install this part?
or how it works?
I read many introductions, and they said the ambient lighting on and off automatically.
Does anyone has the detail informations of this part?
Thanks!
francoxie is offline   Reply With Quote
Old 08-15-2009, 06:43 AM   #2 (permalink)
I just had the Brabus ambient lighting installed in my car by my dealer. The wiring connects to the main wiring harness through the SAM and needs to be activated in order to work in the car (according to the dealer). The brackets install under the dash in the flat area where the two lower dash panels are bolted together. There are two LED light fixtures for each side. One is a bright one (the round one) that illuminates when the door is opened. The other one is rectangular and dimly lit. This one illuminates when the headlights (or parking lights) are on similarly to what Mercedes uses in the footwells for their ambient lighting. The part itself is actually stamped with a MB logo and has an s-class part number on it, so it is the exact same unit from MB. It adds an nice effect at night to the interior both for entry and while driving. Hope this helps.
SmartOneDC is offline   Reply With Quote
Old 08-15-2009, 07:01 AM   #3 (permalink)
For sale pm for details
Turbo42's Avatar
i will post them for you in just a minute
Old 08-15-2009, 07:07 AM   #4 (permalink)
Turbo42's Avatar
The ambiance illumination package
contents includes four adapter cables (2, 3,
4, 7), the use of which is dependent on the
vehicle equipment
1 Disconnect ground line of battery
2 Remove paneling on right A-pillar
3 Remove inside rearview mirror
4 Remove front roof frame paneling
Remove bolts (1) on SAM control unit
(N10/10)
6 Unclip SAM control unit (N10/10) in rear
area (arrow A) and route downwards until
plug 8 is accessible
Install
7.1 Connect adapter cable (2, 3, 4) to plug 8 of For vehicles without code (V54) Rain/light AZ82.20-P-0001-02MC
SAM control unit (N10/10) sensor C
Plug adapter cable (4) with yellow/white
line into pin 4 of gray plug insert 8 (5).
Plug adapter cable (3) with yellow/black line
into pin 19 of gray plug insert 8 (5).
Plug adapter cable (2) with gray/blue line
into pin 10 of gray plug insert 8 (5).
Insert disconnected lines into connector
(2.1, 3.1, 4.1) of relevant adapter cable (2,
3, 4).
7.2 Connect adapter cable (3, 4, 7) to plug 8 of For vehicles with code (V54) Rain/light SAM control unit (N10/10) sensor F
7.3 Connect adapter cable (2, 7) to plug 5 of For vehicles with code (V54) Rain/light
SAM control unit (N10/10) sensor and daytime running lights retrofit E
8 Insert fuse holder (arrow B) with fuse at The slots of the fuse holder (arrow B)
SAM control unit (N10/10) are coded.
The fuse has a rating of
5 amps.
9 Connect ground line of main ambiance
illumination wiring harness (6) to left interior floor ground
10 Route main ambiance illumination wiring The installation position of the main
harness (6) along broken line and fix in ambiance illumination wiring harness (6) is
place using cable ties defined by the length of its individual
branch-off lines.
11 Retrofit ambiance illumination in footwell C
12 Retrofit ambiance illumination in inside rearview mirror C
Hand drill
13 Install front roof frame paneling Model 451.3
14 Install trim at right A-pillar
15 Clip in SAM control unit (N10/10) in rear
area (arrow A) and screw down using bolts
(1)
16 Connect ground cable to battery
17 Perform function test of ambiance When the respective front door is
illumination
Old 08-15-2009, 08:00 AM   #5 (permalink)
babybenz and SmartOneDc,
Thank you very much!
Babybenz~
the instruction is perfect, but do you have any pictures along with? or could you send me the PDF version via email?
Thanks again.
Old 08-15-2009, 11:54 AM   #6 (permalink)
Ambient light pics
Did you ever receive pictures to go along with the detailed instructions?
Thanks
aflyby is offline   Reply With Quote
Old 08-15-2009, 10:04 PM   #7 (permalink)
I noticed that there were several words like "ARROW A or B" in the instructions,
so I guess it has some pictures along with.
Since I don't DIY before, I believe some pics will do a lots of help.
Thanks~
Old 08-15-2009, 10:12 PM   #8 (permalink)
I recieved an e-mail with a link, but It's seem need a password to download.
Thank you all the way~
Brabus rear Cargo area Ambient lighting.. Who has it? Ozzie smart General Discussion 16 02-11-2010 10:52 AM
BRAND New BRABUS 17" rear / 15" front wheels bacque Archive/obsolete (?) threads 13 10-22-2009 12:00 AM
Anyone have the Brabus "Ambient Footwell Lighting"? bull8042 smart General Discussion 4 07-26-2009 07:43 PM
451 BRABUS clock/tach "special sale" smartcarparts Interior & Exterior Styling 0 04-01-2009 12:22 PM
My Ultimate Goal is to Turn my Fortwo Into a "Brabus" jose3030 smart General Discussion 16 12-24-2008 07:41 PM
