LED Fog light installation success - Smart Car of America Forums : Smart Car Forum
Old 02-08-2010, 09:37 AM   #1 (permalink)
LED Fog light installation succeed, NO DEALER NEEDED!!
Hi this is Tyrant from Taiwan. I finished my fog light installation today NO DEALER NEEDED!! I can control the fog light on and off by switching on/off the side light, so no extra switch installed. There are 2 stages or more if you want, 1st stage side light on and fog light off, 2nd stage side light on and fog light on. You can also add the 3rd stage: side light off and fog light on. Here is the procedure.
Note: I use the "LED" light, so the power comsumption is low.
If you want to use the REAL fog light(55W), you have to add a relay series to the output of the control box. use the control box to control the relay and power the relay by battery.
Note: The "control box" was modified from the 3 or 4 stages IC switch used for house light switching. I have procedure to modify it, see below.
Picture of IC lighting switch in Taiwan
It uses 4013 chip to do the controlling
Smart fog light - WRETCH
Circuit diagram of control box
Picture of control box
Wiring method of LED fog light
Wiring method of 55W fog light
1.Unplug the fuse number 6 and 7 or disconnect the battery.
THIS IS VERY IMPORTANT
The fuse unit is under the dashboard of driver side, you have to get down to see it. The fuse number is on it!! (Red 7.5A)
2.Turn the wheel to the extreme right/left
3.Reach your hand inside the hole and find the clip of the grilles, you may
lay on the ground and try which hand is easier to reach in. See my blog
The back side of the grilles see pic below
4.Push out the clip of the grilles, you may push out 3 or 4 clips of them,
and pull the whole grilles out. Then you will see like the pic below.
5.Wiring, I paralleled the right and left side light and connect the power to
the input of the control box I made. Please NOTE: PURE BROWN is the
ground and multi-color is the Positive wire.
6.Put the wire for fog light from top and pull it out from bottom. Please
make sure you leave enough length for wire the fog light connectors.
7.Connect the fog light connector and wire the other head to the output of
the control box.
Wiring diagram
8.Install the LED fog light bulb and CHECK AGAIN make sure positive
connect positive and ground connect ground
9.AFTER making sure of the connection, plug the fuse 6 and 7 and then
turn on the side light power to check. First stage: only side light on, 2nd
stage: side light and fog light on.
10.AFTER check the lights function, install the LED light on the fog light
pedestal and then install the fog light pedestal from the opening. It will
be a little bit tight, you have to squeeze the padestal in.
11.Make sure the pedestal are fixed OK and then install the grilles with for fog light.
tyrant0229 is offline   Reply With Quote
Old 02-08-2010, 03:52 PM   #2 (permalink)
The comparision of before and after!!
Old 02-08-2010, 05:02 PM   #3 (permalink)
Thank you for going to the trouble to take photographs and provide illustrations for your DIY installation. And, congratulations on your success. I hope it provides you many happy and safe miles of enjoyment.
Old 02-08-2010, 07:42 PM   #4 (permalink)
Gilbert's's Avatar
Nice job but, jumpering other circuit to a designed circuit might cuase fire nor malfunction of other ckt.
Old 02-08-2010, 08:03 PM   #5 (permalink)
Brabus007's Avatar
Thanks for the How-To layout...<:-))
Old 02-08-2010, 09:26 PM   #6 (permalink)
SmartDigger's Avatar
Looks good... one might want to get help on this one though. Might be a 4 wrench DIY
Old 02-09-2010, 05:27 AM   #7 (permalink)
Yes, I have thought about it. So I use both side light and fog lght LED version. The power comsumption is almost as much as original T10 bulb. The LED side light is 1.5W each, and the power comsumption of LED fog light maye be less than 5W each. I estimated the extra power is less than 5W total. I think there is no problem with that. But I will keep monitoring the car. See if there were any problem comes out. Thanks. P=IV The extra power comsumption is 5W, so the P=5 and the V=12. The extra I (current) is 5/12 = 0.4167A The fuse is 7.5A. I think there is margin of that
Old 02-09-2010, 08:25 AM   #8 (permalink)
Haha, you are wellcome. But I cannot find the similar product on ebay US and UK. I original plan to find the product for the friends in US or UK but in vain. I majored in ME not EE, so I can only draw the simple AC to DC circuit diagram, as for the control circuit diagram... out of my ability. Actually, I really want to draw the whole circuit diagram to share, but that is too hard for me. Hope you guys can find the product. I think that is a really good device to control the fog light and maintain the integrality as well. Save a lot of money too.
Old 02-09-2010, 12:12 PM   #9 (permalink)
What doesn't appear to be communicated so far: what LED fogs did you use? A manufacturer and part would be great to know.
Old 02-09-2010, 12:54 PM   #10 (permalink)
I bought the LED fog light in the car store in Taiwan, I didnt know the manufacturer but you can type LED H11 1W on ebay. You will find the LED with low power consumption. What else did I miss to say.. I think... I bought the grilles and the fog light pedestal from smart parts direct. AND please check the hole (see picture of procedure 3) see if there is wire popping out after finishing installation. You have to make sure the wire stay inside the hole otherwise your wheel may rub the wire.
LED fog/driving light project. theSMART1 Interior & Exterior 19 08-25-2011 11:40 AM
LED Third Brake Light Jens4365 smart Modifications 12 12-15-2009 07:34 PM
I found a good fog lamp to install (1W LED H11) tyrant0229 smart fortwo (451 - US vehicle) 1 11-26-2009 01:00 PM
45 minutes to becoming a Cruise Control LED installation expert John_H smart Videos 47 04-06-2009 09:32 AM
Cruise control LED installation... Nicholas Interior & Exterior 5 03-23-2009 02:24 PM
