LED Lighting - Smart Car of America Forums : Smart Car Forum
Old 08-13-2008, 09:43 AM   #1 (permalink)
LED Lighting
Did LED's on the SMART
Still sorting out what works best, but this is where I'm at now:
Interior Dome
Super Star 31mm Feston
Festoon Dome Lights
Awesome and staying
You need to bend the tabs in on the spring clips, to hold this shorter lamp.
The LED technology in this lamp is very bright and uniform, so its a much better choice than the 4 LED 36mm (which would fit better).
Rear License Plate
4 LED 36mm Feston, Super White
Festoon Dome Lights
These are perfect and staying.
Rear Stop/Turn/Park
Eagle Eye Tower, Red
1157 1156 Superlumination.com leds (Automotive Replacement Light Bulbs, Headlights, Foglights & Lamps)
I have Super White now, but they look a little orange so, I am exchanging for Red
Rear High Stop
921 9 LED
or
921 Matrix
906 921 Interior Lights
I currently have 921 9 LED in Super White, and it's a bit pink so, I will also exchange for Red and order the 921 Matrix to try also.
Front Park:
Still undecided between:
SMT Tower, Super White
Matrix 5 LED; Cool White
Matrix 5 LED; Warm White
194 168 W5W 2825 Map Led Parking Signal Marker Bulbs
One of my SMT Towers was bad and is getting replaced.
I'm also going to order the 2 different colors of Matrix 5 LED and compare all 3.
I already decided against Amber (stock color) as White gives much more light.
Side Turn
Leaving stock for now
(read below)
Front Turn
Had to change to another Conventional [Non-LED] Bulb
(read below)
I love the LED's and the reduction in alternator load (-2.6A) with lights on and especially with brake pedal depressed (-5.8A).
However, I did get the dreaded fast flash on the left side only.
I did not want to run a load resistor, as that defeats the whole purpose of LED's (low current draw).
I found a conventional bulb with higher current draw (3A) than the stock front turn bulbs (2.2A).
BulbTown.Com - Your Source For Ansi Bulbs, Light Bulbs, Miniature Bulbs & Hard To Find Specialty Bulbs!
These worked like a charm and eliminated the fast flash.
To get them to fit you need to punch one bayonet prong down (very slightly) with a hammer & punch.
Don't grind it off as you will break the seal on the lamp.
I only changed the left side, since my right side has no issues.
I left the stock lamps in the side turns to help with load (see above).
However, their load is minimal, so I will likely change them to 5 LED Matrix in Amber, once I confirm my fast flash does not return.
I can live with conventional bulbs (non-LED) in the Front Turns, since they only flash (low duty cycle) and are not part of the running/parking light system.
lunarx is offline   Reply With Quote
Old 08-13-2008, 09:46 AM   #2 (permalink)
saintload's Avatar
Pictures or it never happened. :P
Just kidding, but in your spare time could you post some pictures? Thanks.
saintload is offline   Reply With Quote
Old 08-13-2008, 10:22 AM   #3 (permalink)
Hey, You can check us out in the vendor section.
We have high powered LED Kits for your SMARTs
Cliff@YourLEDShop is offline   Reply With Quote
Old 06-24-2010, 01:16 AM   #4 (permalink)
Hey, We could offer you the LED replacement auto bulbs and LED flashlight bulbs with high lumens and longest lifetime. Sue from Deshun Technology.
deshunsue is offline   Reply With Quote
Old 06-24-2010, 08:20 PM   #5 (permalink)
SmartDigger's Avatar
I converted mine to LED all the way around. I posted pic here in the past. the blinkers are load resistored front and back. My back LEDs produced Hyper flash also. I used the LED in the front because my Directional bulbs are also my DRL when the lights are off. I was concerned about high heat in the DRLs.
Old 06-24-2010, 11:09 PM   #6 (permalink)
Neonspinnazz's Avatar
So every single bulb is LED?
Or do you still run with the projector beams?
Is there a such thing as LED headlamps?
Old 06-25-2010, 07:14 PM   #7 (permalink)
Headlamps and Fogs are not LED. Fogs will be one of these days.
Old 06-25-2010, 07:36 PM   #8 (permalink)
A quick Google search showed this site with LED fog light bulbs, I would imagine there are others.
18 LED H7 5050 Car Automotive Light Headlight Fog Bulb Lamp - DinoDirect.com
Old 06-25-2010, 08:09 PM   #9 (permalink)
I got all mine here. I would do so again if needed. Super Bright LEDs ? LED Lights, Bulbs, and Accessories
Old 08-19-2010, 05:12 PM   #10 (permalink)
smart....SIZE MATTERS !!
kheran's Avatar
Just wondering....what ones did you get from them? I'm interested in doing up Putt Putt into the LED world.
Kevin
kheran is offline   Reply With Quote
Interior Lighting suggestions? ckigar Interior & Exterior 26 04-01-2009 11:09 AM
LED li lighting smartfloridadad Interior & Exterior 19 08-13-2008 03:41 PM
LED Lighting lunarx Audio & Video 0 08-13-2008 03:11 AM
Lighting the key slot? jwight Interior & Exterior 33 05-10-2008 12:06 AM
Ignition Lighting rrrucke smart Modifications 6 05-01-2008 05:02 AM
