Map light suggestion - Smart Car of America Forums : Smart Car Forum
Old 08-21-2009, 10:18 PM   #1 (permalink)
Not that it's going to happen, but...
WHat I'd really like to see is an aftermarket map light/dome light combination. It would clip into the hole for the stock front dome light, would contain two "push the lens to turn on/off" map lights focussed into the appropriate locations on either side. These would be complemented by a third light that would operate like the current dome light (switchable to "On" "Off" and "Door" settings).
That's what I'd like to see. The map lights in our Toyotas (van, Sienna, Previa and Scion xB all worked along these lines, and we've gotten spoiled as a result.
There there's the whole problem with the missing (from the 451) rear dome light...
Terry Stibal is offline   Reply With Quote
Old 08-22-2009, 02:25 PM   #2 (permalink)
I've had the Sylvania "Dot" strip as the "trunk light" for the last 8 months or so. Double sided trim tape and some adhesion promotor on the smart's side and it's held perfectly. If I ever need to change the batteries I just slide the top section to the side and it comes off and gives access to the batteries. Not as elegant as the LED installs, but simple, effective, fast and inexpensive.
Old 08-22-2009, 06:41 PM   #3 (permalink)
pabille's Avatar
Not quite a map light but this Dot strip has been working well for over 9 months now.
Vanity Mirror Light
I also mounted one above the cargo area.
pabille is offline   Reply With Quote
Old 08-22-2009, 08:20 PM   #4 (permalink)
gbryers's Avatar
I make no claims about the suitability (from your standpoint), nor the mountability in the front roof panel of the smart, not having tried it myself, but here are some possible resources:
AIRCRAFT-STYLE INTERIOR LIGHTS - CarParts Quality Discount Parts and Accessories
Willpak AIRCRAFT-STYLE INTERIOR LIGHTS : JC Whitney: RV Parts & Accessories
Automotive Aircraft Style Lights at Sears Automotive
dome light, map light, rear dome light
Tail Light & Brake Light Problems smartass1 smart General Discussion 6 09-05-2010 10:30 AM
Light Tape: bending light... and other applications BigWarpGuy Tech & Gadgets 33 07-27-2009 10:48 PM
2009 suggestion box GetSmrt28277 Carolinas Chapter 3 09-15-2008 08:13 PM
