Old 06-22-2008, 12:25 PM   #11 (permalink)
16d @ 4's Avatar
Drive: Blue/Black Passion
Originally Posted by Smart Car Geek View Post
Yeah Smart should really make that drain have easier access. They should have used a wider tubing too. Get in a habit of checking that drain on a regular basis.
Does anyone know where this drain tube is?
16d @ 4 is offline   Reply With Quote
Old 06-22-2008, 04:23 PM   #12 (permalink)
smaht's Avatar
Mini Coopers are especially prone to this. It's mold.
When the smell gets noticeable, turn on the heat full strengh and leave the car running for 15 minutes or so. That usually takes care of it for a while. When the smell returns, reapply. I forget if the car has a dust filter in the air system. If so, remove it.
smaht is offline   Reply With Quote
Old 06-22-2008, 05:27 PM   #13 (permalink)
smart happens here!
SmartCard's Avatar
Drive: Red/Bk Cabrio, '04 JCW MCS
That's where I left my old socks!
glad I never had that problem!
9 out of 10 times the musky smell can be attributed to poor drainage of the AC condensate
Old 06-22-2008, 06:00 PM   #14 (permalink)
passenger footwell near the battery. there's a pic floating around on the forum somewhere.
Old 06-22-2008, 09:44 PM   #15 (permalink)
Karl Roth's Avatar
This is the front coming off bottom of the heater /AC unit, smooth black tube
This is the rear The black tube is the condesate drain and the clear tube is for the hydrogen gas generated by the battery
There are commercial solutions to clean the vents a very dilute mix of water and bleach will kill anything in there the best solution for the smell is airflow sufficiant to dry the vents. turn up the fan let it run
Old 06-22-2008, 10:18 PM   #16 (permalink)
saronian's Avatar
Drive: black smart fortwo passion
The AC has an integrated particle filter, any chance that's been contaminated and could be replaced?
Old 06-22-2008, 10:21 PM   #17 (permalink)
Karl Roth's Avatar
The "smell" is coming from the clean side of that filter
Old 06-23-2008, 08:17 AM   #18 (permalink)
tigerwong58's Avatar
Drive: Passion, '08 SLK
This odor is from the environment, high pollen areas can cause the dust filter to be full of this yellow stuff, blended with the condensation from the A/C unit, makes for this musty odor. You may want to call the dealer and ask them, with that low miles they may want to check that the A/C is draining properly and have them check the dust filter.
Old 08-02-2008, 06:27 PM   #19 (permalink)
caravine's Avatar
Drive: Smart Passion
I see this is an old posting, so if this helps..... if you turn off the air conditioning and open the vents before you turn off your ignition, and just let the outside air circulate for a couple minutes, and LEAVE YOUR VENTS OPEN while the car is parked, you don't get the 'stale, mildewy air' smell.
Maybe you've already figured out the solution........
Good luck
caravine is offline   Reply With Quote
Old 08-02-2008, 07:04 PM   #20 (permalink)
dcrooks's Avatar
Drive: 2008 smart Passion Coupe
Good luck
Aren't the vents open by default? When I turn on the A/C, I then have to remember to hit the vent closer to close them to get maximum effect.
My wife and I started to smell the musky smell today and I will for that drain plug to see if that will help.
dcrooks is offline   Reply With Quote
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f75/musky-odor-vents-8209/
Musky odor from the vents on Interior & Exterior | BoardReader This thread Refback 06-23-2008 12:07 PM
