New horn installed - Smart Car of America Forums : Smart Car Forum
Old 10-19-2008, 11:08 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
gbryers's Avatar
New horn installed
Phew - just got done installing a new replacement horn - WOLO BadBoy *Harbor Freight - $39.95). The sucker is LOUD, and it covers both audio ranges (low and high, unlike the stock smart horn).
The directions for side-skirt removal can be found here:
How To: Side Skirt Removal
The directions for the front panel can be found here:
How To:Front Panel Removal
You don't need to remove the whole front end - just the driver's side. The panel will flex out of the way enough (and to spare) with the passenger side still hooked up.
The stock horn in mounted in front of the steel structural plate, the WOLO horn needs to mount behind the panel. It takes a little jiggling to get it there, but once there, no sweat.
Word of warning - the side-skirt is the toughest part of this mod - I would strongly advise having a second person around when you go to re-install the panel - it takes a bit of flexing, and constant pressure over the side clips, to get it on right. I had to bend like a pretzel to put my left knee, left forearm, etc. on enough of the panel to slide it into place.
Old 10-19-2008, 11:43 AM   #2 (permalink)
Is the second person there to take the picture of you bent like a pretzel. Now those are the kind of modification shots I like to see.
Old 10-19-2008, 06:07 PM   #3 (permalink)
Owner for 3.8 years
Kermit's Avatar
You can mount it in front if you go ahead and finish pulling off the front end, the horn would then be pointing in the front direction (I'm saying this from experience, it's how I originally had mine mounted).
I timed pulling my front end yesterday. 6 MINUTES! This is of course with a person following me to take the screws and whatnots from me after I remove them, then another person unscrewing screws too. I know I could cut the 6 minute time too.
TIP
- To reinstall the side skirts is VERY VERY easy. Unscrew those white clips off the car and then slide them in to their respective spots on the skirt. Insert the front of the skirt into the the slot on the front fender then line up the white clips that you attached to the skirt earlier with the screws that stick out from the car. One at a time working from the front to rear just give the outside of the skirt a solid hit where the clip is, the clip will then pop into place. It is much easier that way.
Old 10-19-2008, 06:22 PM   #4 (permalink)
Dont Feed The Trolls ^Mod
jediknight36's Avatar
Is there somewhere on here that shows how to take off the panels or is it in the manual?
Old 10-19-2008, 06:29 PM   #5 (permalink)
SunDiego's Avatar
Check out Evilution - Smart Car Encyclopaedia and FQ101 : Smart Car Modifications for guides.
Old 10-20-2008, 04:20 PM   #6 (permalink)
gbryers's Avatar
Sorry - I just couldn't work the camera while I was balancing all the rest. We'll need an artist's conception for that. But part of it looked like this (I think it was the fourth attempt) "*&^%#&^%*(*&!!!!"
Old 10-20-2008, 04:31 PM   #7 (permalink)
gusfraga's Avatar
Originally Posted by Bum-bling-B View Post
TIP
I did it the other way and it took forever
Old 10-20-2008, 05:55 PM   #8 (permalink)
Owner for 3.8 years
Kermit's Avatar
No worries - first time I did it the other way too, I figured there had to be an easier way and I found it. I didn't think it up though, read it somewhere but I can't remember where so I can't give the rightful person credit for the idea - I will say it wasn't my idea but it does save an extraordinary amount of time.
Old 10-20-2008, 06:02 PM   #9 (permalink)
Arch's Avatar
There's no need to take all that stuff apart. As mentioned endlessly in other horn swap threads; remove left front wheel, a few inner fender liner fasteners, pull liner out of the way, reach in and swap horns. It's tight, but much simpler.
Arch
Arch is offline   Reply With Quote
Old 10-20-2008, 06:14 PM   #10 (permalink)
SunDiego's Avatar
Arch
Some people can't/don't want to remove a wheel on the car themselves
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f75/new-horn-installed-15269/
Smart Car Blog: The Brabus Smart Forfour This thread Refback 10-19-2008 12:42 PM
Horn replacement starlord Smart Owners Club of San Francisco 17 09-23-2011 09:02 AM
horn question jmascia5 New Members Area 4 09-15-2008 05:49 PM
Air Horn smartfloridadad smart Modifications 3 08-22-2008 08:17 PM
Fanfare Horn Old smart Interior & Exterior 17 06-14-2008 08:21 AM
Aftermarket horn video SMART smart Videos 6 05-07-2008 09:49 PM
