HOME FORUMS GALLERY CLUBS
Music Game
Old 11-17-2008, 04:40 PM   #1 (permalink)
Suncoast Smarts Organizer
Wdhitch's Avatar
Drive: 08 smart; 00 Rodeo
Painting interior pieces
There have been a couple of threads lately about painting trim pieces and how to do it IE... sanding, types of spray paint... that sort of thing....
Speaking as a novice who tried it and just had to re-order $60 worth of parts have someone who knows what they are doing handle the job... I sanded, primed, spray-painted, asked advice... and it came out wrong.... very wrong. A couple of pieces were able to be saved but most were a total loss.
Just a piece of advice...
Wdhitch is online now   Reply With Quote
Old 11-17-2008, 04:51 PM   #2 (permalink)
SunDiego's Avatar
Drive: Smart Cabrio, S550, CLS55
Sorry to hear that I would have tried it my self but was too scared so I got a new set painted from Boris & Rachel and sent back my stock pieces. Going to have BabyBenz do it?
Good luck!
Old 11-17-2008, 04:54 PM   #3 (permalink)
Wdhitch's Avatar
yeah....
Old 11-17-2008, 05:03 PM   #4 (permalink)
I painted my clock/tach and speedo bezels aluminum to match the rest of the interior and they came out great. All I did was scuff them lightly with some Scotchbrite, and paint.
turkeylips is offline   Reply With Quote
Old 11-17-2008, 05:06 PM   #5 (permalink)
moderator
Dunerunner's Avatar
Drive: Yellow/Black Passion
Wdhitch - What primer, paint, etc. did you use that ruined the trim pieces, so that others can avoid them!!
Old 11-17-2008, 05:43 PM   #6 (permalink)
Wdhitch's Avatar
The primer and Paint were both Rustoleum Brand. It looks like I sanded the door handles a little too well... and because we couldn't get all the spray paint off, the proper paint wouldn't stick.
Old 11-17-2008, 07:29 PM   #7 (permalink)
I used the Rustoleum for plastic to paint my pod bezels and speedo trim. Not being a painter, I didn't even try sanding before spraying and it worked out perfectly.
Old 11-17-2008, 07:40 PM   #8 (permalink)
babybenz's Avatar
Worked out for now but it will flake off soon if they were not sanded
Old 11-17-2008, 08:02 PM   #9 (permalink)
Bummer
i hope I get lucky. the instructions on the can just said to clean the stuff first so that's all I did.
I really just wanted to say that the Rustoleum (for plastic) didn't do the nasty stuff to me it did to Wdhitch.
BTW, the work you did for him is really sweet looking.
Old 11-17-2008, 09:09 PM   #10 (permalink)
A work in progress...
gbryers's Avatar
Drive: smart Passion/Saturn wagon
Krylon Fusion is designed specifically for outdoor plastics - no prep-work is indicated on the can (though I always reccomend a quick wipe-down with paint thinner or alcohol to remove any oils or gummies that get on surfaces. Only down-side is the limited number of colors currently available. Check out my gallery to see the result (there is at least one pic there of the interior paint.) Biggest thing for diy-ers - practice on something throw-away but as similar in material as possible first, to get comfortable with the product (buy a cheap piece of plastic/plexi at Home Depot or Lowes). When ready, make sure you have a clean, wind-free environment, and take your time. Multiple coats is not a crime if the color is a bit thin the first time, but make sure you allow each coat to tack up appropriately first. Nice, smooth, even passes with the paint each time from 6" to 12" away, and try to not have over-spray too much (I sometimes use a fan at a distance, to get a very gentle air movement, to carry overspray off).
Good luck!
Forum Jump
Getting my interior bits & pieces painted by babybenz! KarenS Interior & Exterior 19 11-19-2008 05:58 PM
Molded color replacement bits and pieces for modding inside???? KarenS Smart Car General Discussion 13 11-04-2008 05:28 PM
Interior carbon fiber pieces? SunDiego Smart Car Modifications 13 08-11-2008 10:04 PM
