Originally Posted by CruisingAZ
Rear fogs are not legal in the US so I doubt the 451 has the function.
Not 100% sure about Arizona but fog lights are specifically addressed within the California Vehicle Code. See (emphasis mine):
Fog Taillamps
<!****** #EndEditable ******> <!****** #BeginEditable "section_number" ******>24602<!****** #EndEditable ******>. <!****** #BeginEditable "section_content" ******>(a) A vehicle may be
equipped with not more than two red fog taillamps mounted on the rear which may be lighted, in addition to the required taillamps, only when atmospheric conditions, such as fog, rain, snow, smoke, or dust, reduce the daytime or nighttime visibility of other vehicles to less than 500 feet.<!****** #EndEditable ******>
<!****** #BeginEditable "addl_section_content" ******> (b) The lamps authorized under subdivision (a) shall be installed as follows:
(1) When two lamps are installed, one shall be mounted at the left side and one at the right side at the same level and as close as practical to the sides.
When one lamp is installed, it shall be mounted as close as practical to the left side or on the center of the vehicle.
(2) The lamps shall be mounted not lower than 12 inches nor higher than 60 inches.
(3) The edge of the lens of the lamp shall be no closer than four inches from the edge of the lens of any stoplamp.
(4) The lamps shall be wired so they can be turned on only when the headlamps are on and shall have a switch that allows them to be turned off when the headlamps are on.
(5) A nonflashing amber pilot light that is lighted when the lamps are turned on shall be mounted in a location readily visible to the driver.
<!****** #BeginEditable "section_change_history" ******>Amended Sec. 30, Ch. 615, Stats. 2004. Effective January 1, 2005.
Amended Sec. 11, Ch. 270, Stats. 2005. Effective January 1, 2006.
This was pulled from the Arizona statute:
Title 28 - Transportation (Arizona Revised Statute)
28-931.
Lamp colors
A. Front clearance lamps and those marker lamps and reflectors mounted on the front or on the side near the front of a vehicle shall display or reflect an amber color.
B. Rear clearance lamps and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
C. All lighting devices and reflectors mounted on the rear of any vehicle shall display or reflect a red color, except that:
1. The stoplight or other signal device may be red, amber or yellow.
2. The light illuminating the license plate or the light emitted by a backup lamp shall be white.
Couldn't find anything with addressing fog lights specifically with my quick search.
Note: Needless to say (but I'll say it anyway). This information is not intended as legal advice or as substitute for legal advice. It is not to be used for anything other than entertainment purposes and sometime idle banter on this forum. The laws of your state may be different. Your mileage may be different. Check with your favorite lawyer for specific legal advice as it may relate to your specific facts.
