Replacing OEM bulbs with LEDs - Smart Car of America Forums : Smart Car Forum
Old 05-01-2008, 10:31 PM   #1 (permalink)
Not including the headlights, of course. Has anyone experimented with just swapping out the old for LEDs?
Good points, bad points, ease of doing it???
Just interested.
mcdnjim is offline   Reply With Quote
Old 05-02-2008, 07:57 AM   #2 (permalink)
Supporting Tuner
Evilution's Avatar
Yes.
Good points: they look good.
Bad points: expensive and don't seem to last long before failing.
Old 05-03-2008, 04:35 PM   #3 (permalink)
pabille's Avatar
I've replaced interior and exterior lights in my other vehicles. I would use Sylvania's Replacement Lamp Guide before ordering from autolumination.com. Unfortunately, Smart isn't listed yet. I could pull bulbs and order after looking at them but I've been busy with that silly thing called work.
I try to use wide angle multiple Superflux LED units offering 1-watt per LED for bright light (many LED units are no where as bright as incandescents). With this, I've been able to replace accessory lights with LED units that are brighter than original incandescents and give me the benefit of faster acting brake lights.
The cost is substantially higher than replacement incandescents but the coolness factor is way increased. I've also never had to replace an LED unit. LEDs should outlast incandescents. They require less energy to operate. The lower energy requirement does create a problem with signal flashers flashing too quickly. That is easily taken care of by load equalizers.
pabille is offline   Reply With Quote
Old 05-03-2008, 05:27 PM   #4 (permalink)
Also you have super bright LED's which I have only used in landscape lighting but also have car bulbs available.
http://www.superbrightleds.com/carbulb-notes.htm
herbvdh is offline   Reply With Quote
Old 05-04-2008, 06:09 AM   #5 (permalink)
lowndex's Avatar
Which bulbs for 451?
As the Smart is not listed, which bulbs do I order for the 451 (tail lights)?
Old 05-04-2008, 09:24 AM   #6 (permalink)
Supporting Tuner
Evilution's Avatar
Bulb list can be found on my site, scroll down to the correct car.
http://evilution.co.uk/index.php?pag...men=Electrical
Old 05-04-2008, 09:37 AM   #7 (permalink)
SmartPassion's Avatar
Thats great info. I assume the 999cc listing is for the American 451?
lighting
Tutorial: Replacing the factory horn SMART Interior & Exterior 142 02-16-2011 09:05 AM
Headlight Bulbs kurier44 smart News & Rumors 12 12-12-2010 09:10 PM
smart is replacing my ECU... anthony94114 smart General Discussion 6 04-28-2008 02:05 PM
Type of Headlight bulbs eqwalker smart News & Rumors 19 11-14-2007 07:49 AM
