Stubby Antenna Whistle - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 08-13-2008, 09:20 AM   #11 (permalink)
Originally Posted by Rmichael1 View Post
How do these install?
Screw off/on. Unscrew the original. Screw on the replacement.
But I like radio reception out in the sticks, so I'll be sticking with the original.
The Silver Pellet is offline   Reply With Quote
Old 08-13-2008, 09:45 AM   #12 (permalink)
Rmichael1's Avatar
really?
Really, 'cause I thought the stubby antenna's were made to replace roof antenna and would therefore require a new base to be put on the smart. However, if it's as easy as screw off/on, I'm doin' it! Thanks!
Rmichael1 is offline   Reply With Quote
Old 08-13-2008, 12:46 PM   #13 (permalink)
gryphon's Avatar
Fixed the Whistle
I managed to fix the whistle I was getting from the stubby antenna. Here's how:
1. Unscrew the antenna from the car so that you can more easily see what you are doing in the following steps.
2. Unscrew the top cone tip from the antenna.
3. Using two 1/16" inside diameter O-rings (got a pkg of ten at Home Depot for $2), slide the O-rings onto the top (smallest) shaft of the antenna. They only need to be pushed on by about an inch. Do use two O-rings, as one did not do the job.
3. Screw the cone back onto the antenna and use a small tool such as a screwdriver to push both O-rings into the cavity on the large end of the cone. With the antenna off the car it's very easy to turn it over and see what you are doing. You don't have to push them in very far.
4. Collapse the antenna assembly completely to push the O-rings up into the cone cavity. Note: The antenna cannot be fully collapsed...there will remain about a 1/16" space.
5. Screw the antenna back onto the stub. The two O-rings change the resonant frequency of the cone's cavity and no more whistle is noted.
Another word here on antennas and reception:
I recently pulled the radio 10 and replaced it with a Pioneer F90BT Navigation/Receiver and found it necessary to put the original equipment antenna back on the car (temporarily) to get adequate signal strength to input weaker stations into the Pioneer. The extended stubby antenna does reduce reception appreciably, but it does look good! AM reception on the Pioneer is almost non-existant, but I don't listen to it anyway. I would not rate FM reception as anything exceptional.
gryphon is offline   Reply With Quote
Old 08-13-2008, 07:52 PM   #14 (permalink)
Rmichael1's Avatar
Should I say, "dooh" (a la Homer Simpson) about how easy it is to install the antenna? I ordered the J series stubby for my smart. Thanks for the info!
Old 08-13-2008, 08:41 PM   #15 (permalink)
Can't be an expert on everything
Nah, you have to ask about stuff. There are so many people on this forum with great ideas, experience and creativity - tapping into it is a treat.
Looking for Antenna (re)placement ifishcat smart Modifications 5 06-15-2008 11:00 AM
shorter antenna donnyonee smart Modifications 2 05-29-2008 05:00 PM
Stubby black pull out Antenna - j series chrisdfw Interior & Exterior 15 05-14-2008 09:59 AM
Stubby antenna for the fortwo SMART Interior & Exterior 22 03-09-2008 09:36 AM
Smart Whistle-Stops U.S. Tour SMART smart News & Rumors 0 06-21-2007 10:13 PM
