Tool to remove seat bolts? - Smart Car of America Forums : Smart Car Forum
Old 10-20-2008, 08:40 PM   #1 (permalink)
I'm looking for the size of the tool to remove the hex bolts on the seat frame. I'm buying something and i need to figure how to get the item home.
bentoutofshape is offline   Reply With Quote
Old 10-20-2008, 08:42 PM   #2 (permalink)
SunDiego's Avatar
Here you go. Hope it helps, Evilution - Smart Car Encyclopaedia
Note from Admin: use this link
http://www.evilution.co.uk/index.php?id=494
the one above is obsolete.
Old 10-20-2008, 09:59 PM   #3 (permalink)
If an encyclopedia doesn't help...
If by "hex bolts on the seat frame" you're referring to the 4 bolts that hold the seat brackets and slider assembly to the floor (the whole seat down to the carpet) it's a T45 Torx bit that you'll need. If you want to release the seat slider from the front bracket (not needed to remove the seat - just take the braket with the seat) you'll also need a T50 Torx bit. If you want to manipulate something else, please be more clear.
Old 10-21-2008, 07:50 AM   #4 (permalink)
cubefx's Avatar
Do not put the key in to the ignition while airbag/seatbelt sensor disconnected. Or even better, disconnect your battery if you planning to remove the seat.
CUBE
Tow hook bolts UFOFORTOM New Mexico Chapter 4 10-01-2008 04:04 PM
Anyone remove the passenger seat? logan74k smart Modifications 5 08-17-2008 05:19 PM
Non-Smart lug bolts DFWehman Archive/obsolete (?) threads 0 08-15-2008 07:07 PM
Smart's New Search Tool greatsign1 smart News & Rumors 5 02-07-2008 11:22 AM
