Trailer wiring/ How to? - Smart Car of America Forums : Smart Car Forum
Old 03-09-2010, 02:23 PM   #1 (permalink)
Ok all you folks tossing hitches on your smarts, How did you wire up the trailer lights.
It's not like I can go pick a "smart" wiring kit off the racks at the store for $10.
Who has done it and do you have any advice?
Old 03-09-2010, 02:35 PM   #2 (permalink)
Owner for 3.8 years
Kermit's Avatar
With wires SILLY! Gosh!
Wire taps on the wires. LED's on my trailer so they don't draw much power eliminating the need for more power.
Old 03-09-2010, 03:52 PM   #3 (permalink)
Details Buddy Details
What side did you Tap into?
Do you have to tap into both sides for the turn signals or does a wire pass through one side to the other?
Where do you run your wires to the hitch area or do you let them dangle out the tailgate?
Smartcaruniverse has a Kit for $70. Sounds a bit pricey to me
Old 03-09-2010, 04:03 PM   #4 (permalink)
Smart Bob's Avatar
One of the owners who tows his smart behind his motorhome picked up a wireless set of tailights. The towing vehicle has a transmitter that sends a signal to the tailights attached to the vehicle you are towing. He picked this set up at a RV or trailer supply house and didn't have to tap into his smarts wiring harness at all. I not sure how the transmitter picks up the signal from the towing vehicle but this set-up might simplify things for you.
Smart Bob is offline   Reply With Quote
Old 03-09-2010, 04:13 PM   #5 (permalink)
I would still need to tap into the smarts wiring to do this, just not the trailer
Not ideal since the trailer will have wiring anyway.
Old 03-09-2010, 04:43 PM   #6 (permalink)
Mister P's Avatar
http://www.smartcaruniverse.com/stor...allationMa.pdf
last time I looked at this it describes the trailer wiring starting on page 5
Mister P is offline   Reply With Quote
Old 03-09-2010, 05:01 PM   #7 (permalink)
Now that PDF Is useful
The wiring info will be very handy, I'm not sure it it looks all that professional in the end.
I guess we don't want wires running behind the panels because of the heat.
Old 03-09-2010, 08:05 PM   #8 (permalink)
SmartDigger's Avatar
I just used a standard 4 wire plug. hooked it up to the wires directly with wire taps. tail light is one R & L blinker is 2 & 3 , 4 is a ground that I hooked to a screw in the back. all wire run under the car zip tied to the hitch. I think I used a knock out to run wire from inside trunk to outside ( the same knock out the car light wires pass though )
Old 03-10-2010, 05:36 AM   #9 (permalink)
Owner for 3.8 years
Kermit's Avatar
Sorry for the delay forest. Same as Digger said was my route. Can't give you pics as the car with the hitch is now my daughters. I will be welding up a hitch similar to ExonicJay's soon. (mostly my uncle will be directing me as my welding isn't too professional)
Old 04-13-2010, 12:12 PM   #10 (permalink)
For those of you who don't want to "tap" into your cars factory wiring for reasons of cutting the original wires try making an adapter. What I did on mine was unplugged the tail lights on both sides and put a volt meter to find out what did what. Then find some spade connectors (male/female) that fit nicely on plugs. Once that's done, make about 4" leads for each connection and just "y" off of the ones that you need to use for your trailer. I know this wont make sense to some people so if you want a diagram or pictures, just let me know.
smartcar451 is offline   Reply With Quote
(451) Wiring diagram for trailer? jwight smart Towing 6 08-25-2009 08:35 PM
Subwoofer wiring CRC2362 smart General Discussion 1 03-14-2009 10:04 AM
Is there a wiring diagram available? gbryers smart Modifications 13 10-13-2008 03:29 PM
Wiring to tow a trailer? wrumbarger smart Towing 3 08-08-2008 09:06 AM
Wiring diagram? jwight smart Modifications 0 01-23-2008 11:53 AM
