Trunk Light mod - complete - Smart Car of America Forums : Smart Car Forum
Old 10-11-2008, 07:20 PM   #1 (permalink)
gbryers's Avatar
Eric N, on SmartInsider, posted a mod he did involving installing 4 LED emitters in the roof panel in the back of the smart, and tying them to the dome light in the front (just giving credit here). I just completed the same mod myself, though I didn't use the same LED's he did, nor did I opt to tie it to the door-open power line. Instead, I added an on/off switch mounted center-front of the ceiling panel (so it is invisible, but easily reached, from the back, and accessible from the seats), and tied it to the "always-on" power line feeding the dome light.
I'll say this - most of the job was easy, even removing the rear ceiling panel, the passenger-side trim panel, and the front ceiling panel, but the sun-roof shade beat me (it is no longer functional since the darned thing unraveled itself, and I don't know how to retension it).
However, here are some pics of the results:
and the switch:
For those interested in the "How-to" that Eric wrote up, you can find it on SmartInsider.com, search for the title "HowTo: Ultimate Smart Trunk Light DIY (lots of pics)"
One of the differences I put in - drilled holes in the vein-supports in the panels, to run the wires through (he cut channels, and admitted he would rather have drilled holes), and I went to the trouble of doing that all the way to the front (he tucked the wires in, instead). I also grounded in the back, so I only had to run the positive lead to the front, and I spliced into the power-feed wire (middle wire in the dome light plug) instead of attaching to the dome light, itself.
As some point, I may go back and add a second power line, and change the switch to a thrre-position, so that I can tie the lights to the door-opening, but I doubt it - I like being able to turn them on only when needed.
Old 10-11-2008, 07:39 PM   #2 (permalink)
banned
Fantastic mod!!!! Nice job... where did you install the switch?
Nevermind... I figured it out.
Old 10-11-2008, 08:37 PM   #3 (permalink)
SunDiego's Avatar
Awesome!!!
Old 10-11-2008, 09:28 PM   #4 (permalink)
Owner for 3.8 years
Kermit's Avatar
Awesome mod. I "started" that mod about 3 weeks ago but have yet to finish it as I soldered into the dome light but grounded myself out. While I was testing - double checking - what was my + I accidentally zapped a fuse. Used what fuses my dad had in his garage, a brand spankin' new box of fuses from Harbor Freight. Little did I know about the RECALL on them. When I soldered the a pigtail onto the courtesy light I left a strand of wire I didn't see that grounded itself across the + and -. When I hooked up the wiring it was fine but then I smelled something, yanked the dome light down but couldn't remove the light as it had melted to the harness. Next it started smoking from the pillar trim so I ripped that off so it wouldn't melt it then I grabbed the burning wires and yanked them out then got under the dash and pulled the fuse. This all happened quickly but was long enough to fry my harness.
I'm working with Harbor Freight right now to get what was damaged fixed. A few trim pieces, dome light, and dome light harness which includes the airbag light wiring. I don't cry too often but I was bawling like a big older 200 pound baby right after this happened.
I was really looking forward to having that cargo area LED lighting. Advance Auto parts sells a ready to go kit, all I needed were some LED holders that I got from Radio Shack. Mine is all installed, just INOP at the moment - think I'll do the rocker switch as that is a SUPER idea! Thanks.
Old 10-11-2008, 09:36 PM   #5 (permalink)
banned
which one was melted... the red or the yellow??
Old 10-11-2008, 09:44 PM   #6 (permalink)
Owner for 3.8 years
Kermit's Avatar
The yellow one is the more modded car. Red will stay essentially stock except for paint, cruise, SGII, and an armrest.
gbryers
- I've got to ask. How did the sunshade unravel itself?
Old 10-11-2008, 09:50 PM   #7 (permalink)
banned
It's possible... I've seen it... I just had mine replaced in Orlando 2 weeks ago... for the 3rd time... as soon as Garrett took the screws out that held it up it almost exploded into about 6 pieces... there isn't much holding it together.
Old 10-11-2008, 09:51 PM   #8 (permalink)
Founder/former Admin.
SMART's Avatar
That is a great mod. Wouldn't it be funny if SMART came out with this option in a year or two!
Old 10-12-2008, 07:41 AM   #9 (permalink)
gbryers's Avatar
Originally Posted by Bum-bling-B View Post
gbryers - I've got to ask. How did the sunshade unravel itself?
When I took the screws out of the passenger-side trim (that holds up the sun screen), and started lowering it, the edge piece tilted enough for the roller in the back to come lose. Once that happened, it snowballed on me in a matter of a few seconds. If the roller comes out, the tension string just flips right off the take-up reels (they are cone-shaped, and don't hold on to the string too well). I haven't been able to get it reset, so right now, it is closed (can't really open it any more), and the driver's-side string hangs down in my face. Guess it is a trip to the dealer to say "look what I've done. Can you fix it?"
Old 10-12-2008, 08:00 AM   #10 (permalink)
Owner for 3.8 years
Kermit's Avatar
My dad had/has a bad sunscreen on his and he got bored and tried to see if he could fix it himself. Same thing happened on him, that's why I had asked. So what you're saying is you had a bad sunscreen and you were trying to see if you can make a slight adjustment on it yourself and it unraveled - hint hint - wink wink - nudge nudge.
Tail Light & Brake Light Problems smartass1 smart General Discussion 6 09-05-2010 10:30 AM
KONIGSEDER complete body kit is available.. smartcarparts Interior & Exterior Styling 10 07-25-2008 11:08 PM
BRABUS complete body kit available smartcarparts Interior & Exterior Styling 5 06-24-2008 09:12 PM
