Old 03-28-2008, 05:10 PM   #1 (permalink)
dsoukup's Avatar
Drive: smart Brabus, Ferrari Dino
Why won't my fog lights light?
I just purchased and installed the Smart accessory (OEM) fog lights. Everything plugged in correctly. I checked for a fuse in the fuse block, checked for power at the switch bank, and so on. Alas, the lights will not light up, the dash indicator does not come on, and the pilot light in the switch only lights up as long as I keep my finger in the switch. My dealer says the SAM (interior control computer must be programmed to allow it to "see" that I now have fog lights. Further he says Smart USA will not support retrofitting its own accessory lights!
I would have ordered them with the car, but I was not able to choose which car I took delivery of...: "Here it is/ Take it, or continue to wait."
Any ideas on how I can get this to work?
dsoukup is offline   Reply With Quote
Old 03-28-2008, 07:01 PM   #2 (permalink)
Dayton smart
Several threads on this; bottom line appears to be your dealer is correct for the time being. smart seems to have no interest in supporting after delivery installation of the lights, or getting the DRL feature activated either. No very customer focused IMHO.
Old 06-17-2008, 10:34 AM   #3 (permalink)
fog lights are only lit if any other lights are on. like road lights.
try it
moddingmaster is offline   Reply With Quote
Old 06-17-2008, 10:44 AM   #4 (permalink)
Dayton smart
Unfortuntely, if they are installed after the car is built there is no way to activate them at this point.
Old 06-17-2008, 11:01 AM   #5 (permalink)
MPrice2984's Avatar
Drive: 2008 Passion, 2006 Sonata
I'd call smartUSA and find someone to discuss it with. I find it hard to comprehend the logic in a design that requires reprogramming the control computer if you want to add factory parts the car is already wired for.
MPrice2984 is online now   Reply With Quote
Old 06-17-2008, 11:09 AM   #6 (permalink)
moderator
Dunerunner's Avatar
Drive: Yellow/Black Passion
I would avoid all the trouble and wire the switch to drive a control relay wired to the lights and a fused hot.
Fog Light Wiring with Bosch Relay
Old 06-17-2008, 11:13 AM   #7 (permalink)
bull8042's Avatar
No one said it was logical, however it has been found to be the truth. Many, including myself are waiting in hopes that smart will release some sort of support to the dealers allowing them to take care of this properly.
As it stands right now, if you must have the fog lights and can't wait, you are going to have to add an external relay to power them as if the wiring does not pre-exist.
Old 06-17-2008, 06:15 PM   #8 (permalink)
Supporting Tuner
Evilution's Avatar
Call me insane but I'd quite like to use the switch that smart supplied and have the little light come up
__________________
My 450 Smart with HID lights joker Smart Car Videos 4 07-26-2009 05:47 AM
Daylight Running Lights Old smart Smart Car Operation and Maintenance 5 09-24-2008 03:03 PM
Running lights ( again ) 4-2NV Interior & Exterior 8 04-03-2008 08:54 PM
Bright Lights! SBibbo Smart Car General Discussion 8 03-07-2008 01:41 PM
When to use fog lights Karl Roth Smart Car General Discussion 56 02-01-2008 12:53 PM
