Amp Location - Smart Car of America Forums : Smart Car Forum
Old 10-21-2009, 06:44 PM   #1 (permalink)
Tango's Avatar
Amp Location
By this time we have a lot of Smarts with subs in their passions!!! Can some of you give suggestiions as to where we are putting the amps? I purchased a smart madness under dash sub box but find myself in a dilema as to where the amp might go. I really thought I would put it under the passenger seat but the amp is just a little to big. I really wanted to maintain the interior as clean so I am at a loss. any suggestions as to where. I even looked for a 600 watt amp that would fit under the seat and still no luck. Thanks Skip
Tango is offline   Reply With Quote
Old 10-21-2009, 07:09 PM   #2 (permalink)
nonuro's Avatar
Look for Sundiego's thread on this.I had mine mounted under the passenger seat.The shop had to ziptie it to the seat frame and velcro the back edge to the carpet.I'll try to get a picture for you tomorrow.
Old 10-21-2009, 07:17 PM   #3 (permalink)
geosynch's Avatar
Yup, it's a tight fit under the passenger seat, but it is possible. Using an xacto knife, cut some of the padding from the back of the carpet, and attach the amp with zip ties or velcro. My Alpine 4.150 is attached with velcro. Hacking the carpet under the seat is what made the difference for me.
As a rule, I'd suggest that the upper dimension for an amp that will fit is an Alpine 4.150. I 'spect googling "alpine 4.150 manual" will get you a .pdf that will show you those dimensions.
Good luck.
geosynch
Old 10-21-2009, 07:38 PM   #4 (permalink)
nonuro's Avatar
DIY Under Seat Amplifier Install
I went through all my old posts about this and found this like. I hope it helps.
Old 10-23-2009, 11:05 AM   #5 (permalink)
here is my amp set up...i had to cut and weld the seat bracket in order for it to fit....i also used velcro to hold it in...and it workd perfectly
and this is the sub its powering....the box goes down behind the seat for the correct air space.
just some food for thought....
mycavs00n04 is offline   Reply With Quote
Old 10-23-2009, 11:12 AM   #6 (permalink)
Tango's Avatar
Something to digest nice setup!
Old 10-23-2009, 11:19 AM   #7 (permalink)
why thank you! those are both old pics... the roof plastics have been sanded down and fiberglassed...they were completely smoothed and painted black to match the car.
Old 10-23-2009, 11:30 AM   #8 (permalink)
sato7's Avatar
It would be more wires but... you could put the amps in the tail gate!
Old 10-23-2009, 11:31 AM   #9 (permalink)
sato7's Avatar
Or you could use a digital amp and I know those fit under the seats NO problem.. an alpine or even a JL
Old 10-23-2009, 11:51 AM   #10 (permalink)
NeWave's Avatar
I followed the DIY link a while back for my under dash. It did the job. It fit almost perfectly under seat.. Then again, mine was only 300 watt...
Toll Transponder location? forestacademy Interior & Exterior 30 08-31-2009 02:15 PM
TPMS Location 2micro4u smart General Discussion 6 01-19-2009 08:12 AM
Tweeter Location Smart990 Audio & Video 11 08-12-2008 03:56 PM
Subwoofer location ARichte23 smart General Discussion 2 11-12-2007 09:44 AM
MP3 Jack Location 2smart4u smart fortwo (451 - US vehicle) 4 10-27-2007 08:58 AM
