Originally Posted by mdfortwoguy
I find that I really have to crank both my iPod and my stereo to have it at an audible level, and not even a level where I really want to get into the music.
Headphone out is not line out. They are two totally different things and you're using the wrong one on your iPod. This is the cable you should be using:
(there are others available on ebay all of the time for much less $)
Engineer-speak follows:
The iPod headphone output is designed to drive low-impedance (~32 ohm), electromagnetic headphones which have a lot of inductance. The iPod line out from the dock connector is designed to drive a high impedance (600 ohm) amplifier's line input (such as the one on your smart car's head unit) which presents very little inductive load.
Another key difference is that the headphone output goes through a variable gain stage so that you can control the level with the volume control (the line output has a fixed gain). That variable gain stage means that the sound is degraded relative to the line output.
Using the line out with the volume control means that, sooner or later, you're likely to forget to change it when going from headphones to car or vice-versa, possibly leading to damage to your headphones, car speakers, car radio, or hearing (ranked in order of severity from least to most).
Now, all of that said, you still may not have enough volume, but, if you don't, the next thing to look at is an external booster. As has been mentioned, Belkin has a combo power supply and booster. I bought one and then proceeded to remove the amplifier so that I could get better quality sound, but I had no need for boost and did not want to risk bumping the setting as I plugged or unplugged the power adapter.
My solution was to remove the factory radio and replace it with an Alpine iDA-X100 head unit:
It interfaces to an iPod digitally through the dock connector, giving complete control via the head unit -- no need to fiddle with the iPod while driving. It does not play CDs, which is a good thing to me given the added complexity and fragility that a mechanical CD transport adds to a head unit. It plays from iPods or thumb drives. When playing from the iPod, it can display album art if present. Other than that, it has AM and FM. You can add other things (CD changers, Bluetooth adapters, etc.) if you are so inclined.
I used a Scosche dash kit (ST2430B) for $20 and a harness and antenna adapter I got for cheap on ebay.
No regrets whatsoever.
