Originally Posted by HGB
I went to HD and bought #8 cable and ran that to the battery terminal with a fuse close to the battery. The fuse I bought at a car stereo place.
I also used #8 to the ground.
There is nothing under the driver's seat that will power the subwoofer. These little mickey mouse wires can power a standard Italian made smart issue sub but not the Bass 600. Under the seat is the black wire that turns on the woofer when the radio is turned on and also the output to feed the signal to the woofer. Don't know the color scheme for those though at this moment.
It is tricky to make a clean connection on the woofer with the overly stiff stranded #8 wire. It is also wise to follow up tightening the wires going into the woofer several times initially for the first two weeks.
I have 8 gauge cabling that I had been figuring I was going to have to end up running, but after doing some research I have come to the conclusion it shouldnt be needed. The bass 600 doesnt seem to have much draw, despite them sticking a "600" on it. As cited by my link above to the Cooper forums (unsurprisingly, another car that the bass 600 is popular with), an electrical guy over there did some good testing on the unit and the consensus is that even the mickey mouse wires to the rear aux/lighter socket of the Mini are adequate. The Bass 600 looks like it only draws around 8 amps when loaded. Which I realize isnt too surprising, given that the fuse it uses is a 15 amp!
The cute thing about this seems to me that if this really did do 600 watt, that would be about 50 amps given 12 volts. That would need at least 10 gauge wire, and obviously that 15 amp fuse on the sub wouldnt cut it.
That 15 amp fuse should blow at anything over about 180 watts on the Bass 600. I suspect there is significant number padding going on.
Anyways, that's my take on it. I'd be curious for the input of a more electronically oriented mind however. John_H, that is probably your cue.
What are your thoughts?
Either way, I turned out to have a bum unit. Even connected directly to a battery (spare motorcycle battery, since it was easier for me to get to) I get no signs of life out of it. Amazon should be shipping out my replacement tomorrow.
