Old 12-10-2008, 08:40 PM   #11 (permalink)
Boosted!
babybenz's Avatar
reason being all those grommets lead to nowhere on the 451 exactly why they got to an inner panel and then are blocked off
Old 12-11-2008, 10:09 PM   #12 (permalink)
geosynch's Avatar
Drive: 2008 smart Cabriolet
Originally Posted by sato7 View Post
if you put the X-over in the door cavity, you don't need to do any of the wire running through the firewall or taking the front panels off........
That's what I did - put the cross over in the door. I considered pulling new, higher gauge, wire from the amp to the speakers like BabyBenz, but wimped out. So, I use the factory harness from the head unit to the inside of the door to the crossover. Then new, higher gauge, wire from the crossover to the tweeter and also the crossover to the mid range speaker. (For a sub, I'm using the 4smart JL unit, which I can recommend.)
I plan on pulling body panels next summer to get them painted. When I do that, I'll upgrade the wiring similar to what BabyBenz is doing.
Best,
geosynch
Anybody installing a ham radio in the smart? nscaler Tech & Gadgets 80 09-27-2009 04:37 AM
Installing Baseplate kleverd1 Smart Car Towing 14 03-12-2009 10:38 PM
semi-free door speakers nonuro Audio & Video 2 07-22-2008 06:01 AM
cables passages - routing new cables to door speakers? cinghi Audio & Video 2 07-08-2008 10:15 AM
What are the best speakers to replace Radio 9 factory speakers with? mnext02 Audio & Video 17 05-20-2008 04:15 AM
