Hey,
Here is step by step speaker installation:
I got Polk db675 for my smart. They are 6 3/4 european size. They are same grade/quality as db651 (6 1/2) but way cheaper from ebay directly from POLK AUDIO. I got mine for $40 shipped.
#1
Remove door panels you can find directions on Evilution website
#2 Expose speaker by folding insulation shield/foam
#3 I would highly recommend to cover your interior , also I taped trash bag to the outside of the door, so I did not have all the shaving and trash inside of my panels.
#4 Drill the grill out from the outside.
#5 As you can see in the photos, there is the 1/2" ridge. You will need to shave factory speaker tabs and everything marked in green. DO NOT cut the ridge off. You only need to shave up to the ridge.
I used DREMEL for this project. Please use safety glasses when working with power tools.
To be continued
