LinkBack (8) Thread Tools Display Modes
Old 06-29-2008, 06:48 PM   8 links from elsewhere to this Post. Click to view. #1 (permalink)
cubefx's Avatar
Drive: Trickcruiser PT, Smart
DIY Step by Step Speaker Installation (door)
Hey,
Here is step by step speaker installation:
I got Polk db675 for my smart. They are 6 3/4 european size. They are same grade/quality as db651 (6 1/2) but way cheaper from ebay directly from POLK AUDIO. I got mine for $40 shipped.
#1
Remove door panels you can find directions on Evilution website
#2 Expose speaker by folding insulation shield/foam
#3 I would highly recommend to cover your interior , also I taped trash bag to the outside of the door, so I did not have all the shaving and trash inside of my panels.
#4 Drill the grill out from the outside.
#5 As you can see in the photos, there is the 1/2" ridge. You will need to shave factory speaker tabs and everything marked in green. DO NOT cut the ridge off. You only need to shave up to the ridge.
I used DREMEL for this project. Please use safety glasses when working with power tools.
To be continued
Old 06-29-2008, 07:05 PM   #2 (permalink)
cubefx's Avatar
#6 Place speaker in the mounting hole and mark holes with awl ( you will need actually puncture hole thru the panel, so you will be able to see exit hole on other side).
#7 Cutout sections of the ridge around holes about 3/4" . Cutout sections marked in red on the photo. SEE PHOTOS.
#8 Here is brackets you will use to screw speakers to the door (brackets came with speakers).
TO BE CONTINUED
Old 06-29-2008, 07:33 PM   #3 (permalink)
cubefx's Avatar
#9 I didn't want to cut factory wiring so I decided to use plug from factory speaker. I cut plug from the factory speaker and soldered it to the new POLK.
#10 Get speaker and the grill and screw them to the door.
#11 Connect wires and secure them with zip ties.
#12 Put insulation cover back and tape it with duct tape.
#13 Put door back together.
Good luck. If you have any questions, please feel free to ask.
CUBE
Old 06-29-2008, 08:09 PM   #4 (permalink)
mike-in-sa's Avatar
Drive: 2002 T-Bird GMC P/U
I installed the polks last week but did a lot less work. I left the stock grills and mounted the speakers inside the doors using the stock mounting points. Cut the wires, crimped on connections. Second door twice as fast as the first. They sound so much better than stock.
Old 06-29-2008, 08:16 PM   #5 (permalink)
Dave777's Avatar
Drive: 2008 smart Passion
Well done DIY. Thanks.
Old 06-29-2008, 08:53 PM   #6 (permalink)
the_dude's Avatar
Drive: smart passion coupe
mike-in-sa...did you use the 6.5" speakers rather than the larger 6.75" ones cube did?
the_dude is offline   Reply With Quote
Old 06-29-2008, 09:07 PM   #7 (permalink)
mike-in-sa's Avatar
You know, They probably were the 6.5's. I'll have to look at the box in the morning. That would explain why I didn't have as much cutting to do.
Old 06-29-2008, 09:10 PM   #8 (permalink)
smartclubsd.com
SunDiego's Avatar
Drive: Smart, C63, CLS55, Chally
Wow those look great
Old 06-29-2008, 10:12 PM   #9 (permalink)
Cubefx,
I commend you for your efforts. I purchased some JL Audio speakers which would have required a similar effort. I simply didn't want to do it. So I went with the Alpine SPS-600 speakers which required no modifications. Maybe one day if there is some must have pair of speakers I will consider it. Great description you have provided. It shows people the difference between putting in "exactly" what you want vs what will fit. I guess the nice thing is you won't have to take the door panels off anymore!
Keep the ideas coming....
Old 06-29-2008, 11:52 PM   #10 (permalink)
moderator
Dunerunner's Avatar
Drive: Yellow/Black Passion
cubefx - Great Post!!! Just the kind of DIY that should get a sticky!! Clean install, clear decriptive step-by-step installation and very nice pics. Well Done!!!!
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f76/diy-step-step-speaker-installation-door-10509/
Speakers - smart USA insider This thread Refback 10-28-2008 02:46 AM
step bystep This thread Refback 09-05-2008 03:05 PM
Speakers - smart USA insider This thread Refback 08-21-2008 02:45 PM
cubefx's 2008 smart fortwo on CarDomain - Page 3 This thread Refback 08-12-2008 10:15 AM
Speakers - smart USA insider This thread Refback 08-11-2008 03:57 AM
Speakers - smart USA insider This thread Refback 08-10-2008 06:05 PM
Speakers - smart USA insider This thread Refback 08-10-2008 05:48 PM
Smart Car Blog This thread Refback 06-29-2008 10:23 PM
Smart 451 (H7) H.I.D Installation- Step by Step instructions with pictures braddman Smart Car Modifications 149 08-12-2009 06:44 PM
Door Speaker Installation -- Shortcuts and Recommendations fmaxwell Audio & Video 39 03-13-2009 08:29 PM
One step closer! jediknight36 Smart Car General Discussion 2 08-08-2008 10:56 AM
Yea! I have taken the First step opas momma New Members Area 3 07-14-2008 05:14 PM
Step inside Green New Members Area 0 08-16-2007 10:09 PM
