I also installed the Alpine SPS-600 speakers ($64 w/shipping on eBay). I cut the insulation foam in a X pattern (rather than a cross "+") so the ends of the cuts were right over the mounting screws. To make sure the duct tape went on nice and flat, I first used some brush-on Krazy Glue to seal the cut. I started by pinching together two of the adjacent corners at the center of the cut after dabbing a little Krazy Glue on the edges and then over the top of the seam for about 1/2". It joins quickly and I was careful not to glue it to the back of the speaker magnet. I did the same thing on the other two pieces and then joined the two halves at the middle, lining up the cuts. Once the center was held together, I continued pinching and gluing down each seam to the end of the cuts. Altogether, it took maybe 4 minutes. I considered leaving it at that, but decided to secure it with the duct tape. With everything perfectly flat, the duct tape went on nicely. I cut round ends on the duct tape so there were no ragged edges or corners. Probably a little too much detail work, but it certainly looked good.
