Old 04-12-2009, 03:07 PM   #1 (permalink)
Drive: 2008 Fortwo Passion
DIY Under Seat Amplifier Install
I was looking for an inexpensive way to install an Amplifier into my 2008 Smart 4two so I could purchase the 8" under-dash sub from 4smartcar.com. This thread will describe how I accomplished this under $200 and less than a couple hours of work.
For some reason this forum won't let me post links or images until I post at least 3 times. This seems silly. Anyway, I'll go post some random stuff elsewhere and post the rest of my message shortly.
kyle2222 is offline   Reply With Quote
Old 04-12-2009, 03:24 PM   #2 (permalink)
installing Sony XM-4S amplifier
I was looking for an inexpensive way to install an Amplifier into my 2008 Smart 4two so I could purchase the 8" under-dash sub from 4smartcar.com (Smart Car Under Dash 8" Subwoofer Bass Solution).
I didn't want to mount behind the seats because I didn't want the Amp to be visible and didn't want to restrict seat movement. I didn't want to spend the $450+ for the Alpine PDX 4.100 so I went in search for small, low-cost 4 channel amplifiers. I came across the Sony XM-4S (Sony XM-4S Slim Series 4-channel car amplifier 50 watts RMS x 4 at Crutchfield.com) that was small and cost $135 w/free shipping from etronics.com. It is a class D amp with more than enough power for the smartcar.
Everything I used for this project:
Sony XM-4S Amplifier from etronics.com ($135)
1000W Amplifier install kit from Fry's ($29) [see picture below]
6' 14 gauge speaker wire from Ace Hardware ($4)
25' 18 gauge speaker wire from Radio Shack ($6)
Scrap mounting plywood from Home Depot ($1)
.5" L brackets from Ace Hardware to mount amp to plywood ($2)
Pack of buttmount crimp connectors from Radio Shack ($3)
Pack of wire taps (connect into 12V aux without cut) from Radio Shack ($2)
14" Industrial strength velcro from Ace Hardware ($4)
1 can of black spraypaint from Ace Hardware ($3)
I didn't want to remove the passenger seat after reading bad stories about airbag lights getting activated. I also didn't want to damage the car in any way -- I was able to do this entire project without drilling or cutting carpet. The only change I made to the car was cutting and splicing the speaker wires behind the stereo. After getting all the material it took about 2 hours to install the amp.
Amplifier mounted to a reverse pyramid plywood structure so it fits flat and snugly under the passenger seat:
Industrial strength velcro to hold it from sliding or otherwise moving:
Amplifier hookup kit purchased from Fry's:
How the cables are run under the passenger carpet:
Picture after install:
You can find information about how to splice the radio speaker connections over at Evilution UK Evilution - Smart Car Encyclopaedia:
(tap) A3 Black Grey 12v Switched
(splice) B3 Orange Speaker Right +
(splice) B4 Brown Orange Speaker Right -
(splice) B5 Green Speaker Left +, Sub pin4
(splice) B6 Brown Green Speaker Left -, Sub pin1
One cool feature of the XM-4S is the "speaker-level inputs with high-level sensing turn-on" which means the amp automatically turns on if the radio is turned on (without the ignition key).
Thanks to Evilution and all the other posters with information that made this possible!
Email me if you have any questions about this project.
Old 04-12-2009, 04:36 PM   #3 (permalink)
nonuro's Avatar
Drive: 2008 smart passion
Excellent! I am going to change the radio myself but I don't have the confidence to do the amp.I think I can do it but I don't want to mess with the electronics.I have an MTX 702 amp and all the wiring kits etc. I am just waiting for the headunit(Kenwood dpx-503) to show up.
Old 04-12-2009, 08:54 PM   #4 (permalink)
Great install and finding of the amp. I'm looking for an amp that fit underneath the seat too, this Sony amp appears to be a great choice. What sub are you running, the JL that comes with the box?
Old 04-18-2009, 10:33 AM   #5 (permalink)
other audio components
Yes, I should have mentioned the other components used for my audio system are:
- Polk Audio DB675 front speakers Door Speaker Installation -- Shortcuts and Recommendations ($90)
- JL Audio 8W3V34 8" sub Smart Car Under Dash 8" Subwoofer Bass Solution (see above)
- LiquidAux to connect iPhone/iPod iphone and Smart? connected through/behind glovebox ($55)
The stock radio AM/FM receiver pretty much sucks (seems to be lacking midrange). I've never tried the CD player. However, using an iPod as the audio source (via LiquidAux), my audio system is very good at reproducing quality sound.
Old 04-18-2009, 12:49 PM   #6 (permalink)
headless's Avatar
Drive: smart roadster, Suzuki 4x4
Nice install there buddy, looks a neat job.
I too installed a Sony explod amp in my smart roadster, but there is no room under the seat as it is right on the floor, so I did the same as you and put velcro on the underside but put it upright on the bulkhead behind the seat, as I am a shortarse I don't need the seat all the way back anyway, so it is no problem, and I installed 2 10inch Sony explod subs in the rear trunk, sounds awesome.
the standard smart ICE is only good for throwing in the trashbin.
Ellis
Old 06-10-2009, 12:56 PM   #7 (permalink)
Is there any reason why I've not seen an installation with the amp under the drivers seat? Seems if you removed the premium sub you'd have the same amount of space. Is it a wiring issue?
Jet Pod is offline   Reply With Quote
Old 06-10-2009, 02:18 PM   #8 (permalink)
cubefx's Avatar
Drive: Trickcruiser PT, Smart
There is much less space under the driver seat then under the passenger.
cubefx is online now   Reply With Quote
Old 06-10-2009, 04:04 PM   #9 (permalink)
very clean install!
AcePlatero is offline   Reply With Quote
Old 06-10-2009, 11:41 PM   #10 (permalink)
NeWave's Avatar
Drive: 05 Impala, 09 Passion
Originally Posted by Jet Pod View Post
... Is it a wiring issue?
Plus, it's less hassle to run the wires under the carpet directly between the amp and the sub. And the battery is right there in the passenger footwell where you'd need to connect to anyway.
The only thing I have left to (still) do is secure my amp down so it doesn't go flying when I slam the brakes.... Sounds great though.
subwoofer amp
New Install vpkb1998 Audio & Video 21 03-24-2009 07:10 PM
Car seat? abseventeen Smart Car General Discussion 36 01-06-2009 07:39 PM
New amp install??? Smart990 Audio & Video 1 12-15-2008 06:23 PM
Help with XM install peterbra Audio & Video 26 11-19-2008 06:25 AM
Car seat csh711 Smart Car General Discussion 8 12-21-2007 07:28 PM
