Fuse box adapter - Smart Car of America Forums : Smart Car Forum
Old 09-15-2008, 06:41 PM   #1 (permalink)
Fuse box adapter
Stumbled across this looking for something else; allows wiring directly to the fuse block. Smart Parts Direct Limited Interior cabin - last item on the page.
Old 09-15-2008, 06:50 PM   #2 (permalink)
SunDiego's Avatar
Isn't this basically just a spade connector like you can buy at Radioshack for $0.79? Or something easier to use?
Old 09-15-2008, 07:41 PM   #3 (permalink)
gbryers's Avatar
Old 09-15-2008, 07:44 PM   #4 (permalink)
Not Selling on Ebay
I bought them. Had them mailed from England. Found out my company makes them. DUH!
Old 09-15-2008, 07:47 PM   #5 (permalink)
DFWehman's Avatar
Well, consider it market research or quality control checks... ;)
Old 09-16-2008, 12:05 PM   #6 (permalink)
Supporting Tuner
Evilution's Avatar
They are made by Tyco I believe, these are also used in many Mercedes and can be bought from smart. They are just a glorified spade connector but the whole thing locks into the side of the fusebox so it won't pull out.
__________________
Old 09-16-2008, 06:14 PM   #7 (permalink)
RedDogInCan's Avatar
Drive: Pulse
On another (apparently unmentionable) Smart forum, Aaron Lephart said
To the left of the SAM unit is a powered strip (circled in yellow) that has a couple fuses already utilized depending on your smart car options. There are 6 open slots to tap into power from. All you need is the "pigtail" or "holder" that houses the fuse rating of your choice and clicks into the SAM unit.
The Mercedes part number for the pigtail adaptor is 211-545-12-01 and can be purchased at any Mercedes or smart dealership. It's about $6.00. The part number is from a 2003+ E class Mercedes but it is a shared part across the brands.
The fuse block is only restricted by the main fuse size. However I would not use any higher then 30amp.
RedDogInCan is offline   Reply With Quote
Old 09-16-2008, 06:16 PM   #8 (permalink)
SunDiego's Avatar
Originally Posted by RedDogInCan View Post
See this post for details on how they fit the fuse box.
Link doesn't work?
Old 09-16-2008, 08:53 PM   #9 (permalink)
Thanks for the photo - lot easier to see how it works.
ZenSpeed Adapter Blowout Sale ZenSpeed Vendor Marketplace 19 09-26-2008 05:06 AM
Fuse box on 451 dbatch1715 Interior & Exterior 3 06-10-2008 06:45 AM
Wellsmart Adapter Status/Check out these rims... iconpyro smart Wheels & Tires 25 06-10-2008 12:24 AM
Are these wheel adapter spec.s correct? lowndex smart General Discussion 2 05-31-2008 07:33 PM
Where to get double din radio adapter? jpkherd smart General Discussion 5 01-30-2008 09:24 PM
