Help Me Plz!!!/audio Hook-up - Smart Car of America Forums : Smart Car Forum
Old 06-16-2008, 08:33 AM   #1 (permalink)
p1nball's Avatar
Need Help Hooking up these items. Boss TW-15 Tweeters, Kenwood head unit KDC 738U, Polk DB 651 6.5 for doors. Best way to use front and rear outputs from head unit, EG;front for tweeters with or without crossovers,rear outputs for doors speakers. of just use front only with tweeters with crossovers and the door speakers!! p1nball THANKS
Note Added pix's in Audio@video Gallery. Well I will end this Post. no replys, will work it out!!
Old 06-16-2008, 02:36 PM   #2 (permalink)
Fredvon4's Avatar
P1ball
Both tweeters and sub woofers are designed to have a very specific frequency range they work in and adding a signal out side of that frequency range can damage them or your apmlifier (even the dinky 50W on in the head unit).
So to answer one of you many questions...
you can send the front output to the door 6.5" speakers first and put the crossover after them and the tweeters. This will put the full 20Hz to 26Khz audio frequency to the Polk 651s and limit the audio frequency to the tweeters to only the signal above 2500Hz (every thing below 2500Hz is too powerfull for the tweeters)
Your Head unit also sends a signal out to the rear channel
So you could use the rear channel for the door 651s and send the front channel to the tweeters through the crossover Boss provided
I sort of recommend this method because in my, car the tweeters over power the factory door speakers and cause the sound stage to sound like it is just behind the rev and clock pods....
If you set it up for the "fronts" to be tweeters and "rears" to be the doors then you can use the fader control top shift the sound stage a bit
When I re do mine in the next few weeks I am adding 4" mids in the rear hatch sides and home brew short depth 8' sub woofer and amp where the factory crap is under the driver seat
I will replace the factory speakers with Boss 6.5s and silk domed tweeters with supplied crossovers
I am still fussing with what head unit I want ...real hard to find all the features I want in one box
RDS
HD
Sirius
USB
Blue tooth
The RDS seems to be a rare item in most Head units
Old 06-16-2008, 03:20 PM   #3 (permalink)
p1nball's Avatar
Thanks FREDVON4, Will Take your advice ,and do it like you said frnt channel to tweeters, and rear channel to the 651's Thank you again" p1nball"
Old 06-16-2008, 07:48 PM   #4 (permalink)
nemo1's Avatar
Can you add more information as to the wiring? In the "premium" sound package it appears that the tweeters and powered subwoofer are connected in parallel to the main speaker outputs. Do you have any more specific information?
nemo1 is offline   Reply With Quote
Old 06-17-2008, 10:26 AM   #5 (permalink)
Fredvon4's Avatar
Nemo1
Not sure what you are asking
A lot depends on if you are keeping the radio 10 or adding a headunit
I intend run all new speaker and power wires and leave the factory speaker wiring and connectors in place un hacked...I will store the radio 10 and sub woofer so I can put it all back to factory come sale or trade in time
It seems to me, from the few diagrams I have seen, that the radio 10 has the tweeter crossover designed in... they send tweeter left and right as seperate circuits...they send door left and right as seperat circuit and steal the powered sub woofer signal from one ( or both ) of the door speaker circuits I assume in the under seat powered 30 amp assy has a low pass filter to block the mid and high frequrncy signals
Old 06-17-2008, 01:03 PM   #6 (permalink)
bull8042's Avatar
..... and home brew short depth 8' sub woofer ......
HOLY DOO DOO Fred! Where in the &!$*# are you going to find room to mount an 8ft sub?!?!
Old 06-23-2008, 01:11 PM   #7 (permalink)
Fredvon4's Avatar
8 foot sub.... damn I need to pay attention to ' or " usage...but for the record... of the many concerts I went to in my youth, I am convinced several of then had 12' speakers
Largest speakers I ever had were a set of Sansui with 15" woofers and they would move a full wall locker across my barracks room.... grin
Old 06-23-2008, 08:59 PM   #8 (permalink)
iconpyro's Avatar
An 8" sub will work, some people mount it under the dash, I am trying to design a JL 13" shallow sub in a downfiring position underneath the seat. The woofer is only 2.5" thick... So yes you can mount an 8" sub, kicker,sony,kenwood, and pioneer all make one.
iconpyro is offline   Reply With Quote
Old 07-03-2008, 07:35 PM   #9 (permalink)
nemo1's Avatar
Nemo1
Fred, thanks for the info. Good idea keeping the radio 10. I was going to sell it. I hooked up my Kenwood. There are crossover settings that I can adjust to make sure the tweeters get the right freq. I'm going to keep the stock speakers for now.
Old 07-04-2008, 08:38 PM   #10 (permalink)
arturo.vega's Avatar
Drive: Pulse
Fredvon4, please post some pictures of your subwoofer installed as soon as you have it up & running
arturo.vega is offline   Reply With Quote
iPod Shuffle 1st gen hook-up?? Trubluesue Audio & Video 6 07-29-2008 08:33 AM
Car Audio installations in DFW area chrisdfw Texas Chapter 3 04-21-2008 06:31 PM
Added an Audio & Video Gallery SMART Audio & Video 0 03-01-2008 12:10 AM
Audio fear in the rear? SMART Audio & Video 6 02-29-2008 11:24 PM
Smart Car Tow Hook seamo Archive/obsolete (?) threads 0 11-17-2007 09:52 AM
