Hidden GPS and Satellite antennae for Passion? - Page 4 - Smart Car of America Forums : Smart Car Forum
Old 02-22-2009, 08:44 PM   #31 (permalink)
ck_az,
can I ask, how do you have your GPS attached? I want to attach my little Garmin Nuvi where you have yours. RAM makes a mount I can use, but I am wondering how you stuck your GPS to your dash.
Originally Posted by ck_az View Post
Here's a picture of mine. I don't have XM/Sirius yet. This mod took a whole 20 minutes to complete. Thanks for the idea folks... I have it held in place with a little bit of velcro.
Now you see it, now you don't.....
Good reception even in my garage with quick satellite acquisition. The extra cable is tucked up in the dash with a fast-tie. I need to come up with a way to hide the cable when the GPS is not in the car.
NuBiker is offline   Reply With Quote
Old 05-01-2009, 07:06 PM   #32 (permalink)
Sorry I am not on the site enough anymore. Here's a link to my mounting solution. Still happy with it.
Yet Another Tech Blog Smart Cupholder GPS Mount
Old 05-01-2009, 07:10 PM   #33 (permalink)
Originally Posted by NuBiker View Post
ck_az,
Is that a Kenwood 5120? If so, why would you have another Navi?
back to the topic... I have my antenna in the same location, however, may move to the open since map calculation is slightly off with the antenna hidden.
Old 05-01-2009, 09:00 PM   #34 (permalink)
Mom liked you better
The Rigger's Avatar
XM antenna under the service flap - very easy to do, works great.
That's where I put the antenna for my GPS. Works fine.
EDIT: The 2610 has a combined power plug/speaker for the voice-nav to yell at you with when you get lost, which I plugged into the "accessory port" in the car, and ran the cord up through the dash & out the top near the pods. The antenna cable comes out of the dash in the same spot. I ground a notch with a Dremel tool in the edge of the radio trim for the cables to exit the dash. The GPS itself rides between the speedo cluster and the tach pod, resting (for now) in a Garmin no-slip beanbag mount until I decided whether to permanently mount one of their locking mounts in that spot. Photos are on the last page of my Smugmug gallery, http://rigger.smugmug.com/gallery/7998960_9syXf
Old 05-01-2009, 10:16 PM   #35 (permalink)
SmartDigger's Avatar
I use the old window mount. the power cord is ran under the dash to the fuse box.
Old 05-03-2009, 04:46 PM   #36 (permalink)
brett2658's Avatar
how did you attach the antenna to the roof? thank just relocated much better does not drop signal now like it did on the dash. the only thing is that my sirius antenna sticks out past the trim by a half inch. next i'm working on putting it on the top of the liftgate and hiding it under a bmw shark fin off a E93 hard top conv. pictures as soon as i figure out how to post
brett2658 is offline   Reply With Quote
Old 05-04-2009, 12:13 AM   #37 (permalink)
Stocker's Avatar
Hi brett2658,
My XM antenna was attached to the roof with double stick tape. That tape didn't hold up to the heat from the sun. So a bracket was added that tucked under the body panel.
My XM antenna was recently moved to the location in the front of the car above the tridion cell, hidden by the headliner. That has been the best place for my XM antenna.
Stocker is offline   Reply With Quote
Breathless New CES Stealth Drop Down hidden Tip Exhaust System BreathlessPerformance Performance & Handling 25 01-29-2009 07:32 PM
Aftermarket Navi / Bluetooth / Satellite Radio rrrucke Audio & Video 15 12-29-2008 12:31 PM
Radio 9 hidden menus MercuryX100 smart Operation and Maintenance 17 10-27-2008 10:15 PM
Satellite radio option? Carnut Tech & Gadgets 24 07-21-2008 05:30 AM
