The SMART CAR OF AMERICA community is a social utility that connects you with fellow smart enthusiasts.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
Going to change out radio #9, Need help on how to remove it. Also if there is a vender that sales the bezel for the SMART!! THANKS FOR WHAT HELP ANYONE CAN POST pinball
You need to carefully pry or pull the piece under the radio that has the heated seat and lock buttons out. Under this is a screw that needs to be removed. Then just reach up on top of the dash where the edge of the plastic piece that surrounds the radio and all the heater controlls begins and pull. You should easily be able to pull or gently pry the entire piece off. Behind it are the screws holding the radio in. I had to remove my radio to find the end of the plug to install my guage pods. It is very easy.
Use a magnetic retrieval tool when you are removing the Torx 25 screw behind the switch panel. If not, it WILL fall off the screwdriver and down (way down) into the dash!
The radio is held in with (4) more Torx 25 screws.
I have extra dash kits and will sell you one at my cost if you need one.
