How to Remove Trim Around Audio System - Smart Car of America Forums : Smart Car Forum
Old 03-13-2009, 03:45 PM   #1 (permalink)
raytmercer's Avatar
I would like to route cables (audio, power and antenna) to an XM on top of the headunit. How do you remove the trim around the headunit to find a path for the cables?
raytmercer is offline   Reply With Quote
Old 03-13-2009, 03:52 PM   #2 (permalink)
Owner for 3.8 years
Kermit's Avatar
pull the center button panel below it out, there is T-15? torx head screw under there. CAREFULLY remove that making sure not drop it. Once the screw is out the panel will pop off.
Old 03-13-2009, 04:23 PM   #3 (permalink)
SunDiego's Avatar
I believe it is a T-15. Use a magnetized screw of put a papertowl or something behind it just in case, so you can catch it. Then like Bum-bling-B said, the top just pulls off (it's held on with about 3 clips that undo when you pull it up and out).
Old 03-13-2009, 06:12 PM   #4 (permalink)
Some instructions I put together long ago for getting to the radio is on page 3 of this document and appears to need a T-25.
Button bank, screw(s), pull.
Old 03-13-2009, 06:42 PM   #5 (permalink)
smartHHO's Avatar
You silly Smarties being Dumb. Torx 25 on the screw.
Old 03-13-2009, 09:40 PM   #6 (permalink)
Owner for 3.8 years
Kermit's Avatar
Sorry dumbsmartHHO - it's been a while since I have had to pull any radio trim which is why I put ? behind the T-15. Why didn't you answer earlier right after the question was asked if you're so "smart".
New audio system w/ speakers in rear.. SunDiego Audio & Video 11 08-25-2010 03:24 PM
Nav/iPod Audio System Install? supermartyo San Diego smart Owners 3 02-17-2009 10:12 AM
How to remove AVIC-D3? SunDiego Audio & Video 18 10-10-2008 09:13 AM
New Audio System AVIC-F90BT fun42 Audio & Video 3 07-02-2008 08:55 PM
Can't remove key Karl Roth smart Operation and Maintenance 0 02-20-2008 08:37 AM
