Kenwood DNX5120 rear camera Problem - Smart Car of America Forums : Smart Car Forum
Old 04-25-2009, 01:03 PM   #1 (permalink)
HI Anyone can help? I did installed the rear camera on my Kenwood DNX5120 but not work when I reverse, If I hold on the NAV key for 2 second and then reverse then the camera is work. anyone what wrong will this and help?
scion126 is offline   Reply With Quote
Old 04-25-2009, 01:59 PM   #2 (permalink)
Do you have your reverse wire hooked up?
Old 04-25-2009, 08:46 PM   #3 (permalink)
Napoleon12's Avatar
^^^^ good point. did you tag the right wire????
Old 04-26-2009, 09:44 PM   #4 (permalink)
If I did't tag a right wire,why when I hold the NAV for 2 sec then put to reverse then work fine,if I hold NAV for 2 sec,but no put to reverse camera not work. Is that right?
Old 04-27-2009, 12:23 AM   #5 (permalink)
I thought holding the NAV for 2 seconds brought up the rear view camera independent of gear. No?
Old 04-27-2009, 02:52 AM   #6 (permalink)
did you know how can I fix it,please help
Old 04-27-2009, 09:05 AM   #7 (permalink)
Napoleon12's Avatar
yes that is how you turn the cam on w/o putting the car in reverse. you can get the wire behind the seats by the ebrake wire or at one of the rear bulbs. so check where you hooked up the wire and also check the setting on the deck make sure it is set right in the menus
Old 04-27-2009, 05:39 PM   #8 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
If all else fails, pay a pro. For me it's worth his fee to avoid headaches like the one you've got.
Old 04-27-2009, 05:46 PM   #9 (permalink)
SmartTech's Avatar
you need to take the purple wire and T-tap it in to one of the reverse light wires.
Old 04-28-2009, 02:06 AM   #10 (permalink)
Thanks all,let me try to found out is it hooked with the purple wire and t-tap it in the reverse light wires.
thanks all again
Kenwood DNX5120 install & comments. Arch Audio & Video 19 01-12-2011 11:09 AM
How about a rear-view camera for the Smart? Bremer Speck smart General Discussion 51 07-11-2009 08:21 PM
Kenwood DNX5120 - Custom Startup Screen vpkb1998 Audio & Video 0 02-10-2009 09:16 PM
Sun Shade For Kenwood DNX5120 smarteepants smart General Discussion 3 01-30-2009 09:07 PM
more kenwood 5120 camera and xm questions Trena Audio & Video 5 09-22-2008 08:34 PM
