If you just run that lead to ground, you remove the inhibit input sensor in the Navigation and can then input destination changes while the vehicle is in motion. This, of course; should be done by your co-pilot so that you are not distracted while driving. If you want to be legal, there should be a switch on the "P" break that transmits a ground signal to the ECU. Connect to that. Personally, I just grounded the lead.
