Parrot MK6100 Bluetooth handsfree installation. - Smart Car of America Forums : Smart Car Forum
Old 03-29-2008, 06:09 PM   #1 (permalink)
The Parrot MK6100 bluetooth system is an almost plug & play installation. The kit comes with an ISO harness that is plug compatible with the 451 & it's radio. Only one change is needed. The power leads for the processor box are attached to the wrong pins. Simple fix. The orange & red power wires have fuses & them and are labeled. Clip both of them near where they enter the ISO socket.
Next take a quick splice and attach the red power wire labeled "12v Battery" to the orange wire on the parrot harness. Then attach the orange wire labeled "12v Ignition" and attach it to the green wire on the parrot harness.
Thats it. Pull the radio, unplug the A & B plugs from the radio & plug them into the sockets on the parrot harness. Plug the harness plugs into the radio. Plug the harness into the parrot processor box. Place the display & remote microphone where you want them & run the wires back to the box. Everything is keyed so you can't get it wrong. My only complaint was that the cable for the display wasn't long enough to put it over the mirror where I wanted it. I ran the wire out the large square hole in the button panel & pressed the panel in on top of it. Not elegant but a good damage free temporary mount.
gamsberry is offline   Reply With Quote
Old 03-29-2008, 06:40 PM   #2 (permalink)
Founder/former Admin.
SMART's Avatar
So does this require you to install a microphone as well? Can you explain to me what technology and use this system provides... I'm uber noob when it comes to bluetooth.
Old 03-29-2008, 07:10 PM   #3 (permalink)
Simply put it turns the car into a giant headset. Once its been set up when you start the car it automatically connects to your phone (if it has bluetooth) and any calls you place or receive are heard over the car's speakers.
Bluetooth is just the name for the wireless link from the phone to the handsfree kit.
This kit has a microphone built into the display When a call comes in it automatically mutes the radio and announces the callers name if its in your phones phonebook. You answer by pushing a button on the remote. It is just like using any speakerphone. End the call by pushing the other button on the remote & the radio automatically unmutes.
The smart is fairly noisy at freeway speeds so none of these things work perfectly. But it is a lot better than fumbling with the phone itself in traffic.
Old 03-30-2008, 03:28 AM   #4 (permalink)
The Super Shoe
mdfortwoguy's Avatar
Does anyone know of a possible comparison between the smart bluetooth kit and the Parrot as far as quality?
Quite frankly, IMO, the smart kit looks like a crappy CD changer remote that you would buy at Wal*Mart... this looks much smaller and more elegant.
Old 03-30-2008, 10:35 AM   #5 (permalink)
spdickey's Avatar
Both installs look a bit messy to me. Here's my Bluetooth solution for my smartie. $60 at Costco.
Review here http://blog.treonauts.com/2007/12/jabra-sp5050-bl.html
Jabra SP5050 Bluetooth Car Kit
Old 05-09-2008, 01:52 PM   #6 (permalink)
MK6100 arrived today, SMART ForTwo Passion 84bhp arrives in two weeks.
Interesting post, only one I could find out there on installing the MK6100 into a SMART ForTwo 451. I'm in the UK but the vehicles are most likely pretty identical with regard to audio connections etc.
Quick question, how did you notice the pins were incorrect, was the unit not displaying 'Goodbye' on turning off ignition ? The manual makes comment of this and suggests reversing the two fuse holders. Would this have the same net effect as your description above ?
Many thanks
Chris
(UK)
ChrisDolphin is offline   Reply With Quote
Old 05-09-2008, 10:35 PM   #7 (permalink)
Many thanks
Chris
(UK)
I'd like to say that I carefully examined the connector pinouts but in reality I just plugged it all in & when nothing happened I started digging deeper. Fortunately the smoke stayed on the inside. In the harness's original form 12v switched is connected to 12v constant & 12v constant is connected to an unused pin. So just swapping @ the fuses wouldn't work. You could swap them then cut just the harness end of the red wire & move it to green. That should work & you'd only have to splice one wire.
Old 05-10-2008, 11:09 AM   #8 (permalink)
Thanks for that, I'll see what happens in a couple of weeks when I get the Smart and install the kit.
Have you tried the music streaming ? Anything additional needed to be done there ? I'm not looking for perfect sound, just some music from the iPod (with a bluetooth connector) or my HTC Tytn II phone.
Chris
Old 05-11-2008, 10:45 PM   #9 (permalink)
Chris
It does work but it didn't sound very good at all. At first I thought it was because it was only driving the small speakers on the dash but when I checked it was driving all of them. It will sound better through the aux in on the radio.
Old 05-13-2008, 11:55 PM   #10 (permalink)
You dont have the wiring diagram for the SMART ISO Socket do you ? (only I notice the yellow pad with doodles on it...) When I mentioned your post to Parrot they simply say "you must check the live with a multimeter before connecting"...er...which isnt exactly very helpful. If you have the pin settings then I'd appreciate it.
Regards
Chris
PS - Parrot are now saying the SMART ISO layout would be useful etc - if you have it.
Bluetooth? 08-4-2 smart fortwo (451 - US vehicle) 10 11-06-2008 06:46 AM
Aftermarket stereo installation tee4 Audio & Video 38 08-16-2008 06:16 PM
Smart Bluetooth ? JeffLAustin smart General Discussion 7 02-25-2008 10:58 PM
Remote Start Installation helidrvr smart General Discussion 5 02-15-2008 03:26 PM
OEM smart bluetooth module? gmkid smart General Discussion 16 02-03-2008 10:30 PM
